Food Mixers Logo
E
Ed Hunley Posted on Mar 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A200, 1st gear had no torque(I could stop by hand). Found & replaced key on low speed gear. It sheared it again. It is just shearing it on the flat gear part, not the bevel gear part. I'm thinking it might be something in the clutch bearings inside the gear, but don't know anything about them.
Todd Arndt
Level 3:
Top Expert:
  • Master 2,044 Answers
  • Posted on Mar 01, 2014
Todd Arndt
Master
Level 3:
Top Expert:
Answers
2044
Questions
Helped
583763
Points
5934
I have had my Kitchen Aid since 2003 and never had this problem. If this has happened to you more than once, I would call Kitchen Aid and explain the issue to them. My sister had an Issue with her new Kitchen Aid and they had her bring it for service and they replaced it with a NEW mixer. Kitchen Aid is very good with brand accountability.
4 Related Answers
Anonymous
  • 640 Answers
  • Posted on Feb 12, 2009
SOURCE: no power in 1 2 gears 3 runs great
Yes,but they are key's.I'm a hobart tech is the mixer apart?
Anonymous
  • Posted on Jan 20, 2009
SOURCE: A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Anonymous
  • 130 Answers
  • Posted on Apr 10, 2010
SOURCE: Position and direction of gear slow speed and key on bevel gear.
Here is a link to a users website where it is claimed that they have the parts catalog . . . good luck!
https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FresourcecenterZ2FDiscontinuedZ2520ProductZ2520DocumentationZ2FF13453.pdf&reason=0&formdir=2
Bob
vestxre
  • 120 Answers
  • Posted on Sep 13, 2011
SOURCE: Hobart A-200 F, Serial Number:
There is a lever that is riveted to the shaft that controls the movement of the diving key. It may be broken. Email me and let me know what you found. [email protected]
KitchenAid Professional 5 Quart stand mixer grain mill won't grind?
From what I know about these and industrial Hobart mixers is that where drive gears are on a shaft they are held by a shear pin that goes right through the gear and the shaft. They are made to shear if the grinder or planetary head is strained. It shears the pin instead of damaging the motor or shredding gears. When they do shear, there is often enough friction to turn the attachment, but not enough force under load. I see two shear pins in this diagram 19/8 and part 14/8. The diagram also show the orientation of bevel gears.
https://www.google.com/search?q=olympus+s924+manual
A Moulinex Coffee Mill might be a better solution for grinding wheat.
Hobart A200 mixer. 1st gear has no torque, I can stop it by hand. I found the key sheared on the low speed gear(flat gear, beveled gear part wasn't sheared). I replaced the key, & it sheared it again...
Ed, if you continue to do it yourself, the end result will be tossing good money out. Have a professional check the system and save the unit from permanent damage. Chipping parts of a gear off means a serious resistance force or action has occurred. One force is slowing down as the other is speeding up. Gear alignment can be moved off center, or a sudden application (sudden stop or start) can damage the least resistant parts. For example, when a hook turns within the mixing chamber and the resistance of the content is too great on the turning shaft and gears, which ever part is weakest will break. Complicated I guess.
2helpful
Hobart Mixer D300, When mixing mashed potatoes paddle will only turn in low gear. When product is mashed with milk added it sometimes will turn in 2nd gear, but never in top. When this happens, motor is...
Sounds like the keys in the shifting sleeve may be sheared. The transmission will have to be disassembled and checked for broken parts. Check www.hobartservice.com for your local Hobart office.
1helpful
2answers
I hAVE A HOBART 200T FIRST AND THIRD GEAR WORK FINE BUT SECOND GEAR DOES NOT SEEM TO GRAB WITH ANY TORQUE. WHAT MIGHT BE THE PROBLEM?
I would say without looking at it a key is sheared or gear teeth are worn on the gear.usually its a sheared key,however if the mixer is older they use a dive key assembly which you would have to replace the shaft.I'm a hobart tech and repair these mixers often,any ? let me know.What is the ml # on the data plate?
2answers
mechanictony-
good luck.
Beater mechanizim runs very slow and will not change speed
It sounds like you sheared a key in the transmission.Does any gears work?were you using 1st gear for dough?
2answers
Hobart A200
When you say lag and catch up. This may not be a issue. I have seen this with dough and a spiral hooks on all sizes of Hobarts the hook and dough get in a position to push the hook forward and the drive gears catch back up the hook. in fist gear on the 20 quart this is common for sure. but its normal. if you have a real slip from a sheared key it will not take long to where you can hold the planetary shaft with your hand and stop it. another slip that might be possible is if your mixer has the first generation worm shaft gear Assembly. when it is worn out it will slip you. this is the shaft that drives directly off the motor. you can tell if it's first Gen by it has a large spring on it. the tow later versions are all keyed to the shaft no chance to slip unless a key shears.
Michael
Hobart a200 first gear not working
Sounds like the key is sheared on the gear.
Jun 05, 2008 • Food Mixers
Slips in all gears
you have no speed 1,2,3 right?first thing to do is drop the planetary (this is the bottom with the beater shaft)undo the bolt and it will drop down.you will see 1 gear,that gear should not spin without the shaft spinning too.if it does you have a sheared key on the gear.if you have access to the transmission check the worm gear attached to the motor it has a roll pin through it make sure its not sheared.then look at the top left gear assembly and check for sheared (broken)keys.clean up all the parts,if you dont you could miss something.let me know.
Top Hobart Food Mixers Experts
vince
NOEL
NOEL
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
