Philips GC7430 steam generator steam and then water runs from holes in base of iron
Unit turns on steams as it should then water runs from the holes in the base and soaks the clothes unit has always been cleaned as per the instruction manual and is fairly new but as usual the warrantee is just out of date
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
follow the steps: God bless you If a routine cleaning of steam vents, channels or holes does not clear
the blockages, you can use a steam iron cleaner. This is a mild acid
type of cleaning mixture specially prepared for such a job. No other
form of fluid should be tried; it may damage seals or jointing compounds
used inside the iron.Use distylled water very IMPORTANT. God bless you
Check the water reservoir of the steam generator and look for some hairline cracks. Also a clogged tubing will likely to go back water on reservoir inlet water pouring. Once you found the cracks, seal it with epoxy just enough to fill the cracks. Thanks for asking.
I had same issue , now , once you turn the unit on , you should see displayed 3 steam jets and the flashing standby , turn the dial on the iron to max ,press the steam button on the machine to max steam , leave for a minute or so , now press the steam button on the iron , does it make a noise ? if it does , slightly raise the whole front end of the unit ( easier if you have the iron on the worktop and not on the unit !) for a minute then try and press the steam button on the iron again . I think there is a bit of an issue about the conection between the water tank and the filter . This solved my issues and i do hope it will help you .
Try holding the iron well below the base with the cord straight and pressing the steam button, this will release any airlock caused by a changing the filter
