Bosch Classixx WVF 240S Front Load Washer / Dryer Logo
m
maria Posted on Mar 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Digihome washing machine is not starting
Please let me know how to proceed to get it started.. i think is not working at all as the door is not looking is only making a click but after selecting the program and psess start the button start blinking and nothing happens.. ihave few cloths inside but i guess it should start even empty as i will like to check it if it works or not to report on monday to the landlord... Thanks in advance
Big Steve
Level 3:
  • Master 1,087 Answers
  • Posted on Mar 01, 2014
Big Steve
Master
Level 3:
Answers
1087
Questions
0
Helped
245201
Points
2442
If the door is not locking properly the machine will not start. Try pressing the door closed firmly and if it still does not start its problem for the landlord.
  • maria
    maria Mar 01, 2014
    Thanks! it started!! but i will ask him to include the problem in the inspection report as in future i might not be that lucky and will not start...
5 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on Mar 21, 2008
SOURCE: door won't open Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
The door sensor/ lock is not working well
Anonymous
  • 487 Answers
  • Posted on May 13, 2008
SOURCE: washing machine
This deffenitly could be the brushes. Wierd sound normally comes from the electric sparking between the stator and the brushes. If it are not the brushes the best bet will be the bearing.
Anonymous
  • Posted on May 23, 2008
SOURCE: bosch Axxis problem
Thought these additional details might help as we are having a similar problem.
When the washer is turned on we get a blank screen, then after a bit we see the display flash. After sometime flashing then we see it go to normal and we can run it. It is as almost as if it need to warm up...
We can get the display to show faster, by playing with the knob. However, the machine still needs time before we can use it.
Any ideas?
Thanks in advance.
Anonymous
  • Posted on Aug 22, 2008
SOURCE: bosch axxis wfr2460
replace the main board,
Anonymous
  • Posted on Mar 06, 2009
SOURCE: Bosch Classixx will not start
Just a guess, but it sounds as if the machine doesn't think the door is shut. Try pushing against it as you turn it on, if that works, then I'd guess there's a door shut switch that needs adjusting.
NOTE. This reply is from an amateur guesser who knows nothing.
How do I fix a washing machine that won't start?
While it can be several things, the most common is the door switch. When these fail, the machine thinks the door is still open.
My amana tandem 7300 will not turn on any cycle it will go back to wash but does not turn on it just beeps please help if u can
It may think the door is open, front load machines will not proceed to fill if they cannot sense a locked door...
My washing machine will not lock to wash i have replaced the locking mechanism assembly and the lock lid light just blinks and click near the computer board what els should i try please jelp
How to fix a washing machine door lock in a Hotpoint ...
? 4:21
https://www.youtube.com/watch?v=p14EEa4AYGM
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF In this video, ... How to fix a washing machine door lock in a Hotpoint washing machine ... How to open a washing machine door that won't open normally.
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock the lockand switch assembly might be defective. This is a very ... The Kenmore Elite HE3 is awashing machine by Kenmore. ... Preview my answer. Post my ...
washing machine wont work. the door will not lock to start ...
www.shopyourway.com > Manage My Life > Questions
Manage My Life. washing machine wont work. the door will not lock to start the cycle. all the lights still ... Kenmore HE3T front load washing machine will not start.
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
Read on to learn how easy it is to fix the washing machine yourself... ... found on front load washing machine is the door switch and the door lock and strike.
Bosch classixx wash and dry - washing machine works fine but dryer does not start and door light does not go out?
if the door light is not going out it is an indication that the door switch is not working. this would also cause it to not run because it thinks the door is still open.
My idesit IWB5113 just keeps filling after starting the wash cycle, normal it inject some water then starts washing, my machine just keeps filling and doesn't seem to start the wash cycle, please help
It is possible that the water level sensor has failed and so does not detect to stop the inlet valve from filling.You can remove and check this level sensor normally it can be a damaged diaphragm and replace the same so that the program proceeds to the next stage to start the machinetips to see working of the machine;http://www.espares.co.uk/advice/washing-machines/a/7/1392/how-a-washing-machine-works.html
I have washing machine aqualtis aqgl 129 pm and the ligh start pause flask and the machine dont work
Have you selected a program? Is water available? You haven't selected delay?
Then I suspect it may be a faulty door sensor, it wont start if it thinks the door is not shut. Try opening and reshutting the door.
Cannot load water unless you lift the hose up or else water will drain. Machine stops after washing and rinsing and doesn't want to proceed to spinning.
i think you are talking about the drain pipe if so then it will not work proply unless its a mimium of 18,ins from the ground level,have you moved house and why has this problem started .What hose are yoy telling me about let me know and i will help you.adrian,,,,,,,,
Door not locking nor spin cycle not working
Hi.
Before proceeding to spin the timer does a check on the lid switch.
You should be able to fix the problem replacing the lid switch.
Regards.
Ginko.
1helpful
Machine will not start, power is on but machine
suggest you check the door lock mechanism. If it is not latching correctly when the door is closed,the program will not proceed.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
