I dont have a remote and i dont know if this m200 is electric start, alarm and or keyless entry
SOURCE: bulldog m200 just stoped working
If it is the same brand and model you will not have to rewire anything
Limited range of your remote controls
could be related to radio frequency interference that comes from
something in your home or in the surrounding environment. Certain
electrical devices can radiate interference; this could be almost
anything that is plugged into an electrical outlet.
Please keep in mind that the device can
be brand new, or can be an item that has been in use for quite a
while. Also, the item may continue to function properly as far as
you are able to tell. The only problem with the item may be that it
has started to broadcast the interference, with no other symptoms
noted.
Some devices are more likely to
generate interference than others. This includes TV cable, cable
amplifiers, surge protectors, fluorescent lights, battery charging
devices (power tools, golf carts, etc.), anything that utilizes a
timer (sprinkler systems, lights, alarm systems, etc.), and a myriad
of others. If the problem seems sporadic, we can safely assume that
the device responsible for the interference is only being operated
during these times. Again, please keep in mind that the age of the
device does not determine if it is capable of broadcasting unwanted
interference. Any electrical device can be the source of the problem.
The first step is replacing the battery
in your remote.
noted.
The first step is replacing the battery in your remote.
