Pulsar Expansion PXN021 Wrist Watch Logo
A
Anonymous Posted on Feb 26, 2014
What battery does pulsar pxn021 take ? - Pulsar Expansion PXN021 Wrist Watch
Battery for Pulsar man's watch 780266?
that looks like a serial number. The 266th watch made in 1978.
Pulsar seem to use a few different batteries.
https://www.google.com/search?q=Battery+for+Pulsar+men%27s+watch+780266
This is the best advice
https://www.fixya.com/support/r27181038-changing_watch_batteries
Pulsar watch model# 660137, what size batteries
Best advice
That model number doesn't follow Pulsar's model numbering scheme and is likely a serial number.
The stock answer is the same battery as the one that is in it.
https://www.google.com/search?q=Pulsar+watch+660137%2C+replacement+batteries
1helpful
2answers
Pulsar analog/digital watch model number 130139
Clearly, it is faulty and has some type of parasitic drain. All watch batteries should last a couple of years. My Seiko last for about 3 to 4 years. Return it to Pulsar or a repair agent for repair.
Pulsar Watches - Tell it your way
https://www.pulsarwatches.com.au
Service & Repairs Service Agents Watch Care FAQs Instruction Manuals · Contact. PULSAR. Pulsar. ©2021 Seiko Australia. All Rights Reserved.
‎Watch Care · ‎Customer Service · ‎Abbreviations · ‎Glossary
Pulsar Watches - Contact
https://www.pulsarwatches-europe.com Pulsar burst onto the world watch scene with the first ever LED watch. Ever since, the name has been synonymous with adventurous and leading edge design.
1helpful
VX82 X530 Battery for Pulsar watch
The VX82 X530 battery is a replacement battery for the Pulsar watch. It is a lithium-ion battery with a capacity of 3.7V and 530mAh. It is important to note that you should only use a battery that is specifically designed for your Pulsar watch, as using the wrong type of battery can damage the watch or be potentially dangerous. Always use caution when changing a watch battery.
Yyou can try searching for "VX82 X530 replacement battery" or "Pulsar watch battery replacement" on online retailers such as Amazon, eBay, or Alibaba. You may also check with the manufacturer of your Pulsar watch or a local watch repair shop for replacement options.
Battery number for pulsar watch. no. on the case is 380292. no. on movement is 7nooa
I want to buy a battery for my Pulsar watch no. 950892, I want to know what the battery has?
1helpful
What type of battery does a Pulsar pxh227 watch take?
The Pulsar pxh227 uses a sr920sw silver oxide battery. An AG3 alkaline battery will also work, is cheaper, but will not last as long as the sr920sw.
Which watch battery fit my Pulsar?
372 or 373, they are interchangeable. It was listed under Seiko and not Pulsar.... the key model # is the vx43, the rest wasn't used. My source: MAXELL 373 SR916SW 1 Battery Official OEM 372 373
Top Pulsar Watches Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Pulsar Watch Expert? Answer questions, earn points and help others
