I installed xp on dell vostro a 840 ,after that i installed all requred driver afterward every thing is working fine except usb device is not detecting , i dont know why.. any suggestion .
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
HI
I HOPE THE FOLLOWING STEPS WILL HELP YOU TO SLOVE THE USB PROBLEM
Click
the "Administrative Tools" link in the Control Panel menu. Click
"Continue." Double-click the "Computer Management" link at the top of
the menu. Click the "Disk Management" button at the left side of the
window to bring up a list of drives on the computer. Right-click the
USB flash drive and choose the "Format" option. Click "Start" and wait
for the formatting process to finish. Restart the computer and then
attempt to use the USB flash drive again.
THANK YOU
PLEASE DON'T FORGET TO RATE .......
