It should be behind the Kicker plate on the front right at the bottom of the machine , it may have a Philips screw on it it may not but be prepared with a couple of heavy towels when you open as a small amount of water will empty when you open it. Through my experience it is best to check the filter once a month because it will not drain and spin properly on the wash cycle if it gets clogged which means a fair amount of water will spill out when you open filter, hope this helps
