We have the Coleman Hot Water on Demand and it has worked fine other than it has never delivered hot water. The water has only ever been warm. The only way we could use it for washing up was to put the water through twice which is a pain. I am wondering if it is only able to heat the water by X degrees? If the ambient temperature of the water is cold is it able to bring it up to say 70 deg Celsius?? Can the thermostat be adjusted? Whats the "over heat" temp. Cheers
SOURCE: We done' use our coleman hot water on demand
I had a similar problem and was able to unscrew the screen at the end of the intake hose and manually move the pump propellor with a long nail which loosened it and it works fine now. I think it had seized with calcium deposit even though I had cleaned it as instructed.
SOURCE: coleman hot water on demand
Does anyone have a AC charger for the Hot Water Heater on Demand? I would be willing to buy one.
Thanks,
llhancock
SOURCE: hi i dont have an opperating instructions for my
You can download and print the complete instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
SOURCE: What is the pumping rate (volume) of the Coleman
I recall 3 and a half liters per minute. More than the Primus and the Cube
