Tissot T-Touch T33759851 Logo
Anonymous Posted on Oct 28, 2007
Battery Change on T-Touch
I took my t-touch to a louzy repair shop in Paris for a battery change. The guy opened the watch in front of me (it was still working), unscrewed the inner battery cover, and replaced the battery; but since then the watch did not work anymore. He tried  several times with also new batteries, but nothing to do.
He told me that probably there was a spring for the negative contact which might have be gotten lose after he opened it, so he try with another spring, fitting it in a small hole, within the battery compartment, but once again the watch was completely dead.
Any insights on the problem will be greately appreciated.
In particular I would like to know if this spring thing should really be there or not, and if the watch must be reset after the new battery is installed (how?).
Thanks a lot
  • Anonymous Nov 04, 2007
    how to open watch
  • NOSKCIRE Aug 14, 2008
    I encountered thew same exact problem yesterday at a dumpy repair shop that I stopped at because I have not been able to locate a battery for the watch anywhere. Well, he had one, and the exact same thing happened. Watch worked, he opened the cover, replaced the battery with a new one, closed it up, watch is dead as a doornail, what gives? Can anyone help with this POS!
Grant Cameron
Level 2:
Habit-Forming:
Scholar:
  • Expert 88 Answers
  • Posted on Oct 28, 2007
Grant Cameron
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
88
Questions
Helped
67822
Points
184
There usually is an AC contact point to reset digital watches. Touching the + and the ac point with a conductive wire usually resets the watch. Not sure about the spring- I'm not going to open my Tissot up unless I have to.
Anonymous
Level 2:
Sniper:
  • Expert 59 Answers
  • Posted on May 27, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
59
Questions
0
Helped
36948
Points
165
I received that watch yesterday for battery change, which I did and watch was running good, and I reset it as well my customer was happy. so if you need help call me at 312 641 7000 or check my webside www.goamfix.com
Watch4maker.com
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Nov 01, 2014
Watch4maker.com
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
67742
Points
51
Watchmaker Video Review For Watchmakers and Watch Fans
If you are in EU with an Easy steps you can send me your watch for battery Change or For Service.I am Tissot T Touch specialist and i am repair 10 of these models every week.If you need more info contact with me [email protected]
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 18, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3664
Points
If the watch is still showing something synchronixe it the procedure id in the manual
1helpful
2answers
Tissot t-touch battery problem
If you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic.
There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery.
I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery
1helpful
Why would a tissot t-touch need an overhaul to replace a dead battery
These babies are notorious for going down the tubes with a battery change. I bet if you get it back it won't work with a new battery. Twice I have replaced batteries and the watch didn't work when I finished. One of them was my own watch, I think $450 is about half the price of a new watch and that is sad. Cool watch just not very long life
2answers
2helpful
Changing battery in my tissot touch watch
Any watch repair shop will do it for you. If you want to do it yourself, you will have to buy special watch tools to open case, unscrew clamps, etc.
1helpful
2answers
Name and battery number for tissot t touch watch
Renata CR1632
http://www.renata.com/pdf/3vlithium/CR1632_v06.pdf
To replace battery you need to have very small screwdriver and some knife to open back cover.
7helpful
I have a Geneve watch and need to change the battery. The case seems to have no way of opening it and seems to be one piece and I took it to the jewelers and they can't replace the battery. Is there any...
Of course, there is the way to change the battery, but for this you have to visit your closest watch repair shop. I do mean WATCH REPAIRS, not the jewellers. Decent watchmaker will definitely open your watch and will replace the battery. Your watch's case appears to be a monoblock. That means you'll need to lift the crystal first, pull the stem second and just then you'll be able to extract watch's movement for replacing battery. Do not forget: jewellers and watchmakers are under one roof, but their trades are completely different. No jeweller can do watchmakers job and vice versa. Rate me, plz.
Mar 19, 2010 • Watches
I have a Pulsar PQ2001 LED wrist watch requiring battery replacement. The battery is covered by a sticker and seems to be ''clipped in.'' I afraid to try to force the 2025 battery out of its position. I...
You need to CAREFULLY peel back that sticker and on either side of that metal clip is a way to unclip it. I really would not recommend someone changing any of their batteries unless its a "cheapo" watch! If you touch the wrong area with the tweezers you could end up having to send it in for repair! Best bet here is to take it to a reputable watch repair shop and let them do it!
Jan 13, 2010 • Watches
23helpful
11answers
"Tissot Touch" Touch screen failure
it all stems from the watch not actually being waterproof it's more water resistant than waterproof. The little indentations on the back that look like they are for a tool to unscrew it are actually holes i guess for the altimeter and meteo so it can sense pressure. Behind the back just behind the holes is a nylon gauze material and underneath this is a sensor slightly recessed and covered with some kind of waterproof substance. As far as i can see the problems lie here any water sweat or other foreign object than gets into this gauze will eventually will clog this gauze material which at first will affect the altimeter then the meteo. When the gauze has been clogged up severely i gets very dirty indeed which means when it gets wet it takes an age to dry out so if you wear it in the shower like i used to it will never dry out this causes the watch to malfunction quite severely. You can actually fix this problem yourself just get a very small flat screwdriver and lever the back off don't worry it's only a push fit and comes of easily you will see straight away a dirty damp smelly clogged up round piece of nylon gauze clean this up with a bit of WARM not boiling soapy water being careful not to disturb the pressure sensor and it's waterproof goo inside then dry it all and put it together
Hope this helps
Dom
England
Top Tissot Watches Experts
Ngoro
john h
k24674
Are you a Tissot Watch Expert? Answer questions, earn points and help others
