Question about Zeiss CARL Visucam PRO NM Fundus Camera
There is no signal from the Visucam PRO NM to computer.
M-audio Fast Track Pro Signal & Clip LED Always ON I have a M-audio Fast Track Pro, I'm facing this weird problem. As soon as I switch the M-audio Power on. I can see the Clip & Signal LED...
I have the same problem. Here is what it looks like. Any ideas? This happens without any inputs. I'm using a macbook air on yosemite but I have tried it with ealier macs and still.
Apr 26, 2012 | Computers & Internet
Hi i need to replace my springs and shocks on my gq patrol and cant find any info on what torque the nuts need to be tightened to
The U bolt tensions need to be 108-147 NM or a little bit tighter...
Shocks need to be tensioned to 47-65 NM for the top nut and the bottom nut should be 17-23 NM...
This is all info for the rear but it is the same for the front, i recently did mine and just tightened everything as tight as possible... Make sure you retension the U-bolts after 50 kms... I am a Qualified Diesel Mechanic just to let you know. You can also buy Manuals from super cheap auto or Auto Pro etc... They are about $40 and are very helpful for any information at all...
Jul 15, 2011 | Audio Players & Recorders
How to replace the ignition switch
  1. If equipped with an air bag, disable the system as outlined in of this repair guide.
  2. If not done already, disconnect the negative battery cable.
  3. Remove the steering wheel, as outlined earlier in this section.
  4. Remove the shaft lock cover.
  5. Remove the shaft lock retaining ring using a suitable lock plate compressor tool to press down the shaft lock. Dispose of the ring.
  6. Remove the shaft lock.
  7. Remove the turn signal canceling cam assembly.
  8. Remove the upper bearing spring.
  9. Remove the thrust washer.
  10. Move the turn signal lever up, into the "right turn" position.
  11. Remove the multi-function lever.
  12. Remove the turn signal switch arm retaining screw.
  13. Remove the turn signal switch screws and let the switch hang freely.
  14. Remove the key from the lock cylinder set.
  15. Remove the buzzer switch assembly.
  16. Reinsert the key in the lock cylinder.
  17. Turn the key to the LOCK position.
  18. Remove the lock retaining screw and remove the lock cylinder.
  19. If equipped with cruise control, remove the housing cover end cap, unplug the cruise control connector and gently pull through the shroud, bowl, and steering column housing assembly.
  20. Remove the washer head screw, the hex nut and dimmer switch.
  21. Remove the mounting stud and ignition switch.
    1. If equipped with cruise control, gently pull the connector through the steering column housing assembly, bowl and shroud and connect the plug.
    2. Install the housing cover end cap and screw and tighten to 17 inch lbs. (1.9 Nm).
    3. Install the ignition switch and mounting stud and tighten the stud to 35 inch lbs. (4.0 Nm). Adjust the ignition switch by moving the switch slider to the extreme left position and then move the slider 1 detent to the right (off lock).
    See Figure 1
    0900c152801dbcc2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Ignition switch adjustment procedure
    1. Install the dimmer switch hex nut, screw, and tighten to 35 inch lbs. (4.0 Nm). Adjust the dimmer switch.
    2. To adjust the dimmer switch, depress the switch slightly to allow insertion of a 3 / 32 in. drill bit into the hole above the actuator rod. Force the switch upward then tighten the screw.
    See Figure 2
    0900c152801dbcc3.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Dimmer switch adjustment procedure
  22. Install the switch using the original screws. Use of screws that are too long could prevent the column from collapsing on impact.
  23. Install the lock cylinder and retaining screws and tighten to 40 inch lbs. (4.5 Nm).
  24. Turn the key to the RUN position.
  25. Install the buzzer switch assembly.
  26. Install the turn signal switch and retaining screws and tighten to 31 inch lbs. (3.5 Nm).
  27. Install the wire protector shield.
  28. Install the turn signal switch arm and retaining screw and tighten to 29 inch lbs. (2.3 Nm).
  29. Install the hazard knob assembly.
  30. Install the multi-function lever.
  31. Install the thrust washer and upper bearing spring.
  32. Lubricate with synthetic grease and install the turn signal canceling cam assembly.
  33. Install the shaft lock.
  34. Install a new shaft lock retaining ring. Align it to the block tooth on the shaft, using a lock plate compressor tool to press down the shaft lock.
  35. Install the shaft lock cover.
  36. Install the steering wheel, as outlined earlier in this section.
  37. Connect the negative battery cable. If equipped, enable the air bag system as outlined in of this repair guide.
Jan 19, 2010 | 1993 Oldsmobile Silhouette
I have installed a D-Link DIR-615 wireless router on my computer. On a second computer I have installed a D-Link DWA-130 wireless N usb adapter. I cannot get to the internet from the second computer - all...
Good question.
Get Network Magic free to eval Network manager. If it is a software issue, NM will solve it for you.
Alternatively, remove all hardware items under question and reseat and try again
In any event NM is a great manager and well worth the few $ needed for 5 licenses for your network resposibilities
Thanks for your interest in FixYa.com
a
Dec 12, 2009 | Computers & Internet
Pro 758 model # 780 turn on computer montor don't turn on
Well i have to practice on my computer then ill tell ya
Dec 12, 2009 | Cars & Trucks
Laptop shows good connection, but cannot connect.
May I recommend you download Network Magic (a Cisco Product - same as Linksys) and l.et NM run its routine on your connection. Google it.
Free top download and use for eval period. read the deal at the web site
I use the paid pro version and I love it.
Oct 22, 2009 | Linksys Wireless-G WRT54G Router
Engonmic hand grip broke off
Check the manuals link and maybe they will replace it under warranty...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Aug 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Zeiss CARL Visucam PRO NM Fundus Camera Logo
140 people viewed this question
Top Zeiss Science & Laboratory Experts
Gep Pep
 Brian Main
Brian Main
Terry
Terry
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
