VERY DANGEROUS YOU NEED TO CHNAGE OUT THE ELECTRICAL PLUG CORD AND CHECK THE TERMINAL BLOCK As u have a short somewhere its easy to change the terminal block
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
Your service manual, or wiring diagram for this machine should be located in the control panel housing. Most likely you have a blown thermal fuse. This part is located on your blower housing right behind the lint screen duct. The power for your gas valve/burner assembly is routed through this part and will be cut off should the drum temperature get too high during operation. The part is a skinny white colored item with a black strip down the center, a quick check would be to see if it has continuity, or simply bypass it briefly to check it. DO NOT leave the part bypassed. To access the part remove your lower front access panel, remove the lint screen for m the dryer and then remove the two quarter inch screws on either side of the lint filter housing to remove the housing. The part number is a 3392519 thermal fuse. Good luck to you on this.
Cheak your safty thermostat at rear of dryer it is located on the blower housing 2 small blue wires go to it.Remove the wires and bypass thermostat.VERY CARFULL MAKE SURE POWER IF OFF FIRST.After bypass plug in and see if it starts.
we just bypass them,unless your going to stick your hand in there during spin cycle,-unplug washer,remove the 2 head screws 1 on each side of the head,flip the head up,you will see the lid switch jack in the middle of the top of washer, unplug it,cut the 2 outside wires and wire nut them together,plug back in,put the head back,plug in washer and your done,this way it cost you nothing to fix,the other way would be around $40,let me know how you do-mike
