Disconnect everything and then plug in only the power. If the light still blinks, the PS is probably damaged and will need to be serviced. If the light doesn't blink, you have a shorted connection. Speaker wires are probably the most likely.
hi
blinking red light means camera is trying to charge flash circuitry. if you cancel flash mode, you can use taking picture. But if you want to repair, your local repair shop would charge around $35 to 75 depend on what they really want to charge.
Thanks and best regard!
The notification lights indicate: Blinking Blue - Bluetooth On Blinking Yellow - WiFi On Blinking Green - GSM (Phone) On Blinking Red - Unread message Continuous Red - Charging
Blinking green when your GSM (phone) is on is the expected behavior.
I had the same problem with flashing red lights. Both sides on a four battery charger. I swapped the batteries to another charger and the batteries were fine. They charged normally. I put some different batteries in the charger and the same flashing light situation. Those batteries also charged normally in a different charger. I looked closely at the back of the charger and, low and behold, "made in China". Why does that not surprise me. The bottom line, it may not be a battery issue.
If you are referring to power light, blinking light specially if red indicates hardware damage. powering down the modem for a minute and powering it back on normally stabilizes it but if not normally it needs replacement.
