I wanna knw how to boot for instaling win 8 dvd in win xp
I was in need for a windows 7 genuine key, and my money were spent very well with www.vinhugo.com. The key worked straight away with no hassle and my windows is now genuine. Plus the support replied straight away to any of my email and questions.
1. Before you begin
To upgrade to Windows 8.1 from Windows Vista or Windows XP, you'll need to install it from a Windows 8.1 DVD and perform a clean installation. This means you won't be able to keep any files, settings, or programs when you upgrade.
Windows 8.1 isn't designed for installation on PCs running Windows Vista or Windows XP, so we strongly recommend you do the following before buying the Windows 8.1 DVD.
Review system requirements
We recommend that you download and run the Windows 8 Upgrade Assistant to check if your PC meets the system requirements for Windows 8. The Windows 8.1 system requirements are nearly the same as the Windows 8 system requirements-so if your PC can run Windows 8, in most cases, you can get the free update to Windows 8.1. Upgrade Assistant will also check program and device compatibility, and provide a free compatibility report.
Still be sure to review the system requirements for Windows 8.1 before buying the Windows 8.1 DVD. We also recommend that you visit your PC manufacturer's website for info about updated drivers and hardware compatibility.
Here is a summary of the system requirements:
If you're unable to install Windows 8.1 on your current PC, you might consider shopping for one of the new generation of PCs that are available today. For more info, see the Windows PC buying guide.
Notes
Check compatibility of programs and devices
The Windows 8 Upgrade Assistant will check if your programs and devices are compatible with Windows 8, but you can checkWindows 8.1 compatibility info for a specific program or device (including info from community forums) in the Windows Compatibility Center, or contact the program or device manufacturer.
Most programs created for earlier versions of Windows will work in Windows 8.1, but some older programs might run poorly or not at all. There are several things you can try to fix compatibility problems. For more info, see Get your apps and devices working in Windows 8.1.
Drivers for basic device functionality are available "in-box" (meaning, as part of the Windows image). This includes drivers for storage, networking, input, and display. These drivers allow you to complete the Windows installation and connect to the Internet. You can get more drivers from Windows Update or from the device manufacturer once you're online. For more info, see Download and install drivers.
Back up your data
Since you won't be able to keep any files, settings, or programs when you upgrade from Windows Vista or Windows XP, we recommend you back up all files and locate any program installation discs (or purchase confirmation emails) prior to updating.
You can transfer files before you upgrade by copying them to an external hard drive, USB flash drive, or CD, and then moving them to the location you want on your new PC. Be sure that the drive or disc has enough space to hold everything you want to move. If don't want to use an external hard drive, USB drive, or CD, you can move your files to SkyDrive to have all your files in one place and have the latest version on your PCs. For more info, see Getting started with SkyDrive.
After you upgrade to Windows 8.1, you'll need your original program installation discs, or purchase confirmation emails if you purchased programs online, to reinstall your programs. Insert the program CD or DVD into your PC or follow the directions in the confirmation email.
If you've been using Outlook Express, Windows Live Mail, or the version of Windows Mail that came with Windows Vista, your email messages and contacts can be imported into Outlook.com using the Mail Migration add-on. For more info, see Import email from a desktop app to Outlook.com.
Note
Compare and decide webpage.
Determine if your PC can run a 64-bit or 32-bit version of Windows
After you open the Windows 8.1 packaging, you'll see two installation discs: a 64-bit version of Windows and a 32-bit version of Windows.
The terms 32-bit and 64-bit refer to the way a PC's processor (also called a CPU), handles info. The 64-bit version of Windows handles large amounts of random access memory (RAM) more effectively than a 32-bit version. To install a 64-bit version of Windows, you need a CPU that's capable of running a 64-bit version.
To see whether a PC running Windows XP is capable of running a 64-bit version of Windows, do the following:
Notes
Find your product key
Your product key should be on the box that the Windows 8.1 DVD came in. It looks like this: PRODUCT KEY: XXXXX-XXXXX-XXXXX-XXXXX-XXXXX.
You'll need to input your product key during installation. It's a 25-character code used to activate Windows, which helps verify that Windows hasn't been used on more PCs than the Microsoft Software License Terms allow.
It's a good idea to save a copy of your product key for your records in case you ever need to reinstall Windows.
Enter your Microsoft account email address and password.If you have more than one Microsoft account, you'll need to choose one. For more info, see Which email address should I use for my Microsoft account?If you already have a Microsoft account
If you signed in to your PC using a Microsoft account before you installed Windows 8.1, then you might not see this step.If you want to create a Microsoft account
Windows 8.1 is designed to be used with a Microsoft account, so we recommend that you give it a try. Simply put, a Microsoft account is the glue that holds together so many useful features of the new Windows. Without one, you won't be able to, for example, get new apps from the Windows Store, automatically sync your settings and documents between PCs, back up your photos to the cloud so you can get to them from anywhere, or see all your contacts from multiple email and social networking accounts together in the People and Mail apps.
But if you're sure you want to use a local account instead, click Create a new account, and then on the new account page, click Continue using my existing account.
SOURCE: hi i wanna install win xp via pen drive to my pc
Go to BIOS setup the do
first boot from USB Drive then Restart you system. then automatically boot windows xp from your pen drive. Do and enjoy with windows xp. For this you need to get a Bootable Pen Drive http://files.extremeoverclocking.com/file.php?f=196
Here is the Tutorial to Installing Microsoft Windows XP from USB
http://compupodia.blogspot.com/2009/08/installing-microsoft-windows-xp-from.html
SOURCE: My laptop is very slow while booting XP.
i guess ur using a licensed and 'updated' antivirus..
howevr, hv a glance ovr the software strength..look for startup items (the programs loaded during startup)..download n install n run 'Statup Control Panel'..
http://www.pcworld.com/downloads/file/fid,7976-order,4-c,desktop/description.html
and microsoft kb890830..remove the unnecessary boot item(s) or do post me a complete list of startup item that the Startup CPL is showing (in itz every tab), i'll guide u..
also u may use 'Advanced System Care Pro' to fix all at a time..
always better to get supervision frm ur system admin/vendor....
SOURCE: compaq v3000 cant play dvd after re install win xp
Try to upgrade your media player or install third party player available on the net which can play dvd.
SOURCE: I M USING WIN XP INSTALLATION CD BUT IT GIVES MESS
Go to BIOS to check the reliability of hdd or if you have a software tool such as "Avanquest System Suite" use it to boot machine from scratch. It will tell u what is really wrong.
SOURCE: 1) not possible to enter the bios boot menue.With
Did you press F12 while booting? That should take you to the boot options menu. Choose CD Rom.
