First of all, you bought a cheap store brand fan! The red light is a battery indicator light, so check your battery. If that doesn't work, then you probably need a new transmitter or receiver or both.
You have a electrical power shortage, when componets demand power it's not there [ that's why some componets slow or stop working ]. Start by cleaning the battery terminals and testing the battery to see if it holds a proper charge [ after fully charging, let the battery sit for a few hours and check the voltage = it should be at least 12 volts. If not, replace. Then check the output of the charging system = mininum of 13.8 volts to maxinum of 15.3 volts, & up to 78 ampress when @ maxinum charing. Then check the starter draw = should be around 260 amps, if it's higher then 300 amps. then replace.
Indicates you have a bad Power Supply, to me. Weak voltage power rail.
1) ALL of the LED lights combined use less than 1 Watt of power. 2) EACH fan uses 2 to 3 Watts 3) A typical Processor can use 51 to 125 Watts. Depends on what Processor it is.
(The Pavilion a6750f uses an ATX power supply, that has a maximum rated wattage of 300 Watts.
NOTE* Computer unplugged from power. Anti-Static Precautions observed.
Anti-Static Precautions: Your body carries Static electricity.
Static will fry out (Short Circuit) the hardware components inside a computer. (You may not even see it, or feel it)
Computer unplugged from power, computer case open, working on a table; TOUCH the metal frame of the open computer case, to relieve your body of Static. Should you leave your computer in the middle of working on it, upon your return be be SURE to Touch the metal frame again.
POWER DISTRIBUTION BOX
Location
Name
Amp
Circuits Protected
A
Trailer Tow
50
Fuse 32/Fuse 26/Electric Brake
B
Fan (Hi)
60
Cooling Fan (CCRM)
C
Start
60
Starter Solenoid/Fuse 30/Fuse 36/Fuse 2
D
Ignition
60
Fuse 6/Fuse 12/ Fuse 8/Fuse 18/Fuse 14/ Fuse 24/Fuse 20/Fuse 21/Fuse 27/Fuse 33
E
Rear Blower/ RAS
60
Rear Heater Blower Motor Rear Air Suspension
F
Seat
60
Power Seats
G
Not Used
H
Fan-Lo
40
Engine Cooling Fans
J
Power Accessory
60
Fuse 13/Fuse 25/ Fuse 1/Fuse 31/Fuse 37/ Fuse 40/Fuse 7/Fuse 19
K
Light
60
Headlamps/Fuse 10/ Fuse 11/Fuse 3/Fuse 9/ Fuse 23/Fuse 29/Fuse 35/Fuse 41/Fuse 17
L
ABS
60
ABS Control/Pump Motor Module
M
Heated Backlight
60
Heated Backlite/Fuse 16/Fuse 28/Fuse 22
N
Fuel
20
PCM/Fuel Pump/CCRM
P
Not Used
R
PCM
15
PCM Memory
S
PCM
30
AX4S/Cylinder Identification Sensor/EDIS Module/PCM Power/EGR Control/HEGO's/IAC/ Injectors/MAFS/VMV
T
Alt./Reg.
15
Generator
U
Air Bag
10
Air Bag (Dedicated)
V
Trans. Light
10
Transmission Indicator Light
W
Fan
10
PCM Fan Monitor
X
Diode
Hood Lamp Diode
Y
Relay
RH Trailer Turn/Stop/Hazard Lamps
Z
Relay
Powertrain Control Module
AA
Relay
Windshield Wiper Speed
BB
Relay
LH Trailer Turn/Stop/Hazard Lamps
CC
Relay
Windshield Washer Pump Motor
DD
Relay
Windshield Wiper Dynamic Brake/Run
The fuses are color-coded by amp rating.
Fuse Value Amps
Color Code
Pink
5
Tan
7.5
Brown
10
Red
15
Light Blue
20
Yellow
25
Natural
30
Light Green
40
Orange
50
Red
60
Blue
