My daughter tried to access my phone with my pattern lock. she did it to many times and now it says i have to access my googled account to unlock it
SOURCE: forgot password to htc hero the google password
format the phone... download the firmware frm the HTC site and follow the instructions
SOURCE: pattern lock on sony ericsson xperia x10i need
*Turn off the phone
*take off battery & put back in
*press and hold down the right & left silver buttons just under the screen
*with stylus press in the hole on the right side of battery
*after 10Sec you will be prompted to press the R key
*If successful press the space key to finalize changes
www.usedcellphoneshop.com
SOURCE: locked out by too many
1. On the computer: Start PC Companion™.
2. On thecomputer: In the Support Zone™ descriptor, in the Software Updatesection click Start > (Repair) and follow the instructions on the PCmonitor screen.
3. Turn off the phone.
4. Connect the USB cable to your computer.
5. On the phone: Press and hold down Back key and connect the USB cable to the phone.
6. Follow the instructions on the screen.
Note : The software in your phone will be replaced. All personal data stored in your phone will be lost.
There is also a way to unlock the pattern screen lock by signing in with your Google account.
1. After 30 seconds, tap Forgot pattern?
2. You need to log in with the primary gmail.com e-mail address and not the alternative email address connected to the Google account.
3. Tap the username field and enter the primary Google account user name.
4. Tap the password field and enter the primary Google account password.
5. Draw a new unlock pattern and tap Continue .
6. Draw the new unlock pattern again and tap Continue .
If these options are not available to you, please describe preciselywhat you see when attempting to connect to your PC and use PCCompanion.
SOURCE: Hi, I need help, I have SAMSUNG Galuxy S (I9000),
Do this but make sure you may wan't to lose files:
1. Turn off the i9000 phone or take out the battery and reinsert it.
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 MATER RESET
Done!
SOURCE: my daughter entered the wrong
For all android devices a google mail account is needed for purchasing apps etc. if he did not set this up and had set the pass code without the email specified the only way to get back into the phone would be to do a complete reset. Before you do this have you tried restarting the device and seeing if it gives you the ability to try to enter the code again, if not here is how to do a factory reset. As stated below this will delete everything on the sd card so i would advise you copy all the files from it onto your computer. the entire process should only take about 10 to 15 minutes depending on the phone sometimes less than this, good luck!
Performing a factory reset (hard reset)
If you're passing your phone on to someone else or your phone has a persistent problem that cannot be solved, you can do a factory reset (also called a hard reset). This returns your phone to the state it was in before the first time you turned it on.
Note: Factory reset will not remove the data and files that are in your phone's microSD card.
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset.
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
