I try to print photos in my computer using the Epson picture mate personal photo lab, but hwen i press the print tab, no printing, no sound.
SOURCE: print the files through epson stylus photo 380
I think you need to add more details to your question. You are unable to print in what system or OS? Windows XP? Vista? Mac? This would help you find a good solution to your problem...
SOURCE: Non-Epson cartridge
Yes this is a common problem. Go to Epsons web site and download any updates and this will usaully fix it. If not reinstall your printer and then again check for updates.
SOURCE: Epson PictureMate personal photo lab
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: Epson Stylus Photo R300 sounds like it's printing
I know there are some cleaning cartridges with a chemical thinner that could clean any ink residual that could interfere with proper function of the printing head.
If this doesn't work you probably have to replace the head.
Check also the flat cable that follows the printing head during movement.
Fabio
I had the same error and I could find no information on what it was or how to fix it so I decided to go trial and error. What I found is that this relates to the print head not being able to completely pass from the left to right side during startup. I had a plastic carriage on the one side that was stuck in a position that stop the carriage from make the complete run from side to side. When I forced the plastic carriage down and it clicked into place the error stopped and the printer started up normally with no codes. If anything is causing the print head to not travel completely from left to right during startup, this will probable cause the code. It will be hard to see if the print head is being obstructed if you don't remove the sides. I hope this helps.
