Samsung Series 7 Chronos Logo
m
monique lamers Posted on Feb 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installation cd boot problem
thulasiramki
Level 2:
Habit-Forming:
  • Expert 152 Answers
  • Posted on Feb 18, 2014
thulasiramki
Expert
Level 2:
Habit-Forming:
Answers
152
Questions
0
Helped
10517
Points
209
When booting the PC press f10 it will shows you boot menu.
I have a mercury board kob p4266ndfsmx, with intel processor and 1 gb ram, dvd writer is working fine, problem is im not able to boot from cd rom even if i choose cdrom as 1st boot device, i have check...
sometime there are an option in the BIOS setting to boot directly on HDD when there are a OS installed try to invert primary and secondary controller (invert HDD and CD-ROM wire on the motherboard)
3answers
Installing window 7 but cd pc not booting from cd
Windows 7 installer is not a CD it is a DVD installer. Cd drive can not read a dvdrom (dvdr or dvdr/w). You must have DVDrom drive to install the windows 7 installer. Here is the video tutorial on how to install windows 7 have a nice a day!
How to instal in pc
Hi, you haven't said for what operating system, but for XP. First you will need to change your primary boot device to CD Rom, to do this boot into BIOS by pressing the F1 key during initial boot fase, save changes after boot device has been selected, insert windows CD into drive and reboot. Select boot from CD, which appears during initial boot fase. Allow files to be installed, once finished you will need to delete operating system and repartition hard drive, then format hard drive. Once this completes PC will reboot, ignor boot from CD and allow PC to boot normally and it will start to install XP.
11helpful
2answers
My acer aspire 5315 always show boot prepare os. When i want to install windows it cannot show cd boot (booting from cd/dvd) so i can't install windows. what is the solution sir? thank.
Restart you computer then hit F2 for Boot Bios Setting then GO TO Advance. Change the SATA Mode . ACHE. ot IDE. or Comfatibility.. then enable the F12 boot. make in enable. the hit F10 for save and exit...
Insert you cd os Installer then hit F12 for **** menu. select the CDROOM for boot....
2answers
How do i install an oparating system in an acer laptop 4230 samueul
to install OS in laptop,its like to install OS to PC.
1.Set up Bios <with pres key "Delete" or "F1" or "F2">Booting Priority (chose Boot from CD/DVD Room).
2.Save and exit (with pres "F10")
3.Wait until text > "Pres any key for Boot from CD/DVD..." you pres any key before the text disapear.
4.and follow the instruction...
2answers
What key do u press so it will boot thru d cd?
Press the "delete" key when you put it on then you bios will come on then you can the do to "chipset features" or "booting" option and change your first boot divice to your cd rom or pressthe F9 button to get a direct boot option(this works in certain pc's)
How did you install xp on your lappy I have a hp pavillion dv5-1104tu and i m wishing to install xp but i m not getting steps to install xp can anyone help me out for this problem
1. Insert the CD in the CD drive and boot up the laptop. Press F12 and select the CD as the temporary boot up device.
If you cannot get the CD to boot up with the CD, then you need to go to the BIOS configuration the change the boot order so that the CD is the first boot device (you can change it back to the hard drive later when you finish installing Windows)
2. Follow the screen instructions to install Windows. I suggest you get a computer friend to help you.
Installing windows using cd
If you have the media (Windows XP CD) you should insert it int othe CD drive then check the BIOS for the boot order and make sure CD is first in the list or when booting up select F12 or whichever function key it may be on your pc to bring up the boot device order and select cd. This should then bring up a prompt that says boot from CD hit enter to do so. It will then boot into hte Windows installation which you can follow through.
Let me know if you need further help.
1helpful
2answers
IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
2answers
How to install windows xp boot cd on acer aspire 4315
When you first start the machine, you need to go into the boot menu and boot from CD drive, or go into bios/utilities set up and set the boot order to boot from CD first. Make sure your XP CD is in the drive, then just follow the prompts.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
