SOURCE: Breitling Aerospace -setting T2
Here is a link for all settings:
vbr.com/docu/breitling4.htm
SOURCE: Breitling watch move fast
No matter what is your watch movement (quartz or mechanical) it can be adjusted to keep time properly.
Bring it to your nearest watchmaker and the problem will be solved.
9 sec a day is far too much for Breitling.
SOURCE: how to set date on breitling watches
On most. Turn the winding screw anti-clockwise until it clicks and pops out slightly. Pull it all the way out or half way out to change the time or date.
SOURCE: Watch looses time. Breitling 1884
It sounds like your either not moving enough to wind it (try winding manually) or it needs a service (gear oil gone sticky) to free it up.
Testimonial: "Thanks for the information."
SOURCE: I've got an older breitling aerospace
I have seen other makes which have described how to do this but you do need the manufacturers instructions. These are frequently obtainable from their web site but in this case I couldn't find any.
However, if you go to their web site (www.breitling.com/zh/index.php#/home/), you will see on the left side of the screen a heading "maintenance centers", click on this and choose the one nearest you.
If you contact them they may be able to talk you through the procedure or send you a set of instructions.
