SOURCE: broken hose connection on intake manifold
This is a ugly thing that happens all the time at my shop. The best way to repair this is to drill the material out and retap the hole . you will need a 1/2 pipe tap, they have them at home depot or your local hardware store . on the pipe tap it tell you what size of drill bit to use . the material in the hole is aluminum and it drills out E-Z. I have also tried to use a small chisle to break out the broken peice out you can do it but you will learn alot of new bad words.The biggest problem is sometimes because of space restriction you have to use a angle drill and a shortend brill bit to even get in the space to drill.Well so far I hav'nt gave you an E-Z way to fix this SORRY. This one is not a very easy one . I hope this helped
