Acer Aspire 5500 5570-2609 Laptop Logo
A
Anonymous Posted on Feb 14, 2014
PCI bus 10, device 9, function 2 - Acer Aspire 5500 5570-2609 Laptop
5 Related Answers
Anonymous
  • 47 Answers
  • Posted on Jan 04, 2008
SOURCE: Resource Conflict - PCI Network Controller in Slot 02
Hi akwasi,
Try pressing F2 and look in the bios for a setting that says "Load Bios defaults". If you have any PCMCI cards inserted please remove them first and try a re-boot.
Have you added any new components on the PCI bus? If you have you need to make sure that the BIOS is allowed to reconfigure the interrupts. The device in slot 03 is conflicting with the integrated network controller hosted on the PCI bus. Remove the device in slot 3 and all should be well.
Most BIOS manufacturers allow the PC/Laptop to manage it's own interrupts, so ensure the device you've inserted allows for this. If it uses fixed interrupts this might be your problem.
A good manual should details the BIOS setting you can adjust in order to get the PCI controller happy again and allow the machine to POST correctly.
Regards,
Spare head 2
Atiq
  • 257 Answers
  • Posted on Apr 24, 2008
check for an update of bios on acer.com it will fix your laptop problem....
Anonymous
  • Posted on Oct 13, 2008
SOURCE: windows will not boot
Just turn-off network boot in your bios
Anonymous
  • Posted on Feb 10, 2010
SOURCE: PCI DRIVER
GO TO ACER SUPPORT AND DOWNLOAD AND INSTALL... ENE Card Reader Driver 3.00.00 THIS WILL FIX YOUR PROBLEM
alien_x
Mike Hidlay
  • 281 Answers
  • Posted on Nov 02, 2010
SOURCE: I have Acer Aspire 5101
you need to flash your bios with a new version try the laptop manufacture's site.
1helpful
Processor upgrade
WHERE IS THE QUESTION.
6helpful
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
11helpful
2answers
PCI Slot 1 (PCI bus 1, device 10, function 0)
Hi there,looks like your devices need updates to function correctly,
from devices manager,
select the device with the yellow question,
right click and click on update
even if you have no disk or internet
let the wizard find the drivers automatically
should be preinstalled with your OS XP
go thru your list and update any other question marks in yellow.
Should be able to update the network device on this system and then connect to the internet to finish anything else
heres the link for the Chaintech motherboards
http://www.download-device-drivers.com/Chaintech.php
Hope this helps,Cheers Misterdj
3helpful
Pci card drivers
you would need to get all the drivers for your laptop from the IBM website and install all of them. If you cant find them or need further help please post back and let me know.
22helpful
5answers
I need drivers for laptop sps 1210
all Drivers for your computer can be found here
u most look what u already got what not
If it helped rate fixya
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
