Question about Frigidaire ATF6000ES Front Load Washer
I receive the code LOC and then PAU.
The machine stopped working . The machine beeps when I push the buttons. That is it.The code L:OC comes up on the digital display, followed by P:AU and then 0:00, and continues to flash between P:AU and 0:00 while I am still pushing the buttons.I have tried unplugging the machine and tried pressing the start and cancel buttons simultaneously. Nothing works.
Anonymous
SOURCE:
Anonymous
  • 19 Answers
SOURCE: "Pau" error message on the ATFB7000ES
take out the plug for 5 min
Posted on Nov 01, 2007
Anonymous
SOURCE: Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
Posted on Aug 19, 2008
Anonymous
SOURCE: Affinity washer displays ERR. PAU and 56
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Posted on Jan 10, 2009
Anonymous
SOURCE: pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Posted on Apr 25, 2009
Kamatchi Kuppusamy
  • 141 Answers
SOURCE: FAFW3577KWO washer-code E11
Your machine may have short circuit with the inlet valve since you are facing problem after 5 to 6 mins you are suppose to change the inlet valve
Posted on Dec 24, 2009
I have teh atf6000ES1
Pau? as in end of life? seems that perhaps the control board is speaking in a foreign language? anything happen recently to make it this unhappy?
May 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Machine stops and PAV appears on the panel
Thank you for your post, campy chaney!
I understand that your Frigidaire washer is displaying an error code of "PAV". "PAV" is not a valid error code, your washer maybe displaying a "PAU" error code. It could be a possible issue with a low light on your LED panel. If it is a "PAU" code that could be an interruption within your cycle. I would suggest performing a reset on your washer and you can do that by flipping the household circuit breaker off for roughly ten minutes. When you restore power to your washer and continue receiving the "PAU" code I would suggest having a professional technician out. This could be a possible problem with your control panel, door latch, or door strike. Since it could be anyone of these underlying having a technician out would help avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Feb 06, 2015 | Frigidaire ATF6000ES Front Load Washer
Code pau
For pause mode, just push the start/pause button again.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Keeps saying PAU
The PAU, or pause, error usually means that the washing machine cycle was interrupted and was not restarted properly. If you try to modify the cycle or start a new one before the first cycle is complete, the PAU error will appear on the display. If the washer was stopped midcycle and not restarted, the cycle must be canceled or completed before a new selection can be made. Push "Start/Pause" to allow the current cycle to finish before making a new selection, or push "Cancel" to stop the current cycle
Oct 15, 2012 | Frigidaire Washing Machines
Have a kenmore front load washer and shows pau 45 in the display. Whatever button i press shows err cannot do anything with the machine.
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2010 | Kenmore 46462 Front Load Washer
FAFW3577KWO washer-code E11 washer will begin wash cycle and stop after 5 or 6 minutes. display reads PAU- when start and cancel buttons are simultaneously pushed I get an E11 code. What is E11?
Dec 24, 2009 | Frigidaire ATF6000ES Front Load Washer
2yr old daughter hit some buttons now it won't - pau 33 pau 33
did you get this fixed? how? my 2 year old son did same thing.
Dec 13, 2009 | Frigidaire ATF6000ES Front Load Washer
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
LOC ERR
The control panel may in *LOCKED* mode. Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel. Make sure the detergent tray is fully closed too.
Feb 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
29 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Marvin
Marvin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
