Do the series of numbers look like a date/time and page number stamp? If so, you need to turn off the Stamp RCV Name feature. This is part of the Advanced Fax features. To access this, press Menu until you see Advanced Fax on the top line of the LCD screen. Press Enter then use the left/right arrows until you see Stamp RCV Name. Press Enter again and use the left/right arrows to select Off. Press Enter to save the setting. Then press Stop/Clear to exit the menu system.
Samsung has the User Manual for the SF-560 here: http://www.samsung.com/levant/support/model/SF-560/XEU . The direct link to the manual in English is currently http://downloadcenter.samsung.com/content/UM/200906/20090617100814640/Guide_English.pdf . See pages 4.4 and 4.5 for the Advanced Fax menu information. These are pages 65 and 66 of the PDF.
I hope this helps. If the digits aren't the date/time/page number, I'm not sure what the footer text is.
SOURCE: Paper jam
The various parts that open up to allow access are monitored by a micro switch. Switch the machine off and open all the access points locate the switch and make sure it is freely working and the connections are all in place. Then come back
SOURCE: Poor Print quality - black lines appear on page
If you see black lines on the drum, it is very likely that the drum unit is bad. Replace the drum unit and rest the drum counter. If you wait too long, you will cause toner build up in the fuser and will cost yourself several hundred dollars to get it replaced. More in labor than parts.
Use a soft cotton or very soft paper towel and wipe the excess toner from the drun. If there are lines worn in the surface of the drum, then replace it ASAP.
SOURCE: brother FAX T74 problem sends black page, copies black page
hello it sounds like you need to have the scannetr replaced
SOURCE: PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
