SOURCE: coffee takes 10 minutes to fill cup and very noisy - Classic
The most common problem with these machines is scale. Using a good descaler to start with may help but may not always solve the problem. If your machine is noisy it is the pump which may need replacing. If you open the steam valve when making the coffee it will shift any air lock. Out with that you may have to remove the shower plate underneath where the coffee handle goes and give it a good clean. Also there is a safety valve inside the group head which may be clogged up. I am a domestic coffee machine engineer based in glasgow and have machines sent to me from all over the UK. It is hard to eally fix problems without actually seeing the machine as it could really be anything. Boilers are small so tend to fill with scale and ****. go to www.theespressoshop.co.uk if you require any more assistance.
Kind Regards
David
Domestic Coffee Service
SOURCE: Gaggia Titanium - Cold coffee although producing steam.
The only thing that comes to mind is one of the thermostats on the boiler.
SOURCE: syncrony digital gaggia coffee maker leakage+ventilate message
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
