This is the most practical Service Repair Manual for the Bobcat 641 642 643 Skid Steer Loader Workshop Service Repair Manual Download ever compiled by mankind. This DOWNLOAD contains of high quality diagrams and instructions on how to service and repair your Bobcat 641 642 643 ,you can download it.This is a must for the Do-It-Yourselfer!
I ran into the same issue, instead of buying a replacement remote I was able to dial in a Vip 211 dish network remote control with remote code 643 in AUX setting. Then once the code was in, i pressed the 6 key on the remote and now I can listen to audio on the music port. The 643 code refers to the first Panasonic amplifier/receiver in the code list. To further clarify, I pressed AUX for 4 seconds, pressed 2 to signal I am programming an amplifier/receiver device, then punched in 643 then pound sign.
Good luck with yours.
check the status of the device under Device Manager first and see if it was properly installed. If yes, you may use the wireless zero configuration utility built-in to XP or Vista. If your OS is lower than XP you have the use the utility provided by D-link. It usually comes with a CD installer for its driver and utility.
Please rate and see if it helps. Thanks and goodluck.
