Samsung Xpress M2875FD Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Printer, Copier, Scanner, Fax - 29 ppm Mono Print - 4800 x 600 dpi Print - 29 cpm Mono Copy LED - 1200 dpi Optical Scan - Automatic Duplex Print - 251 sheets Input Logo
A
Anonymous Posted on Feb 12, 2014
Samsung Xpress M2875FD Laser reset firmware - Samsung Xpress M2875FD Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Printer, Copier, Scanner, Fax - 29 ppm Mono Print - 4800 x 600 dpi Print - 29 cpm Mono Copy LED - 1200 dpi Optical Scan - Automatic Duplex Print - 251 sheets Input
HEMANT GROVER
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Samsung Expert 171 Answers
  • Posted on Oct 02, 2015
HEMANT GROVER
Samsung Expert
Level 2:
Cheetah:
Answers
171
Questions
0
Helped
119213
Points
243
Download from samsung website,may use foll link:
http://www.samsung.com/uk/consumer/it/printer-multifunction/black-white-multifunction-printers/SL-M2875FD/SEE
2answers
Samsung Xpress m2070 system initialize error
The system initialize error is typically caused by a firmware issue or a hardware problem, such as a malfunctioning sensor or motor. Here are some additional troubleshooting steps you can try:
  1. Check the error log: The M2070 printer has an error log that can help diagnose the cause of the system initialize error. To access the error log, go to the printer's menu and navigate to "Maintenance > System Data > Service Report." Look for any error codes or messages that may indicate the cause of the problem.
  2. Perform a firmware update: The latest firmware update for the M2070 printer can help resolve any known issues with the printer's firmware. To update the firmware, visit Samsung's website and download the latest firmware for the M2070 printer. Follow the instructions provided to update the firmware.
  3. Reset the printer to its default settings: Press and hold the Stop button on the printer for about 10 seconds until the printer restarts. This will reset the printer to its default settings and may resolve the system initialize error.
  4. Clean the inside of the printer: Open the front cover and remove the toner cartridge. Use a clean, dry cloth to wipe any dust or debris from the inside of the printer, particularly around the paper path and rollers. This can help resolve any issues caused by dirt or debris interfering with the printer's operation.
  5. Check the printer's hardware: If none of the above steps resolve the issue, there may be a hardware problem with the printer that requires professional repair or replacement. Some common hardware issues that can cause the system initialize error include a malfunctioning sensor, motor, or control board.
Samsung Xpress SL-C410W Color Laser Printer. Tengo una impresora laser c410w, enciende luz azul, pero no arranca. Cuando le abro la bandeja, queda luz verde fija
https://ftp.hp.com/pub/softlib/software13/printers/SS/Common_SW/WIN_EPM_V2.00.01.35.exe
"Please download and install Samsung Easy Printer Manager from the link. The application will diagnose the issue for you."
1helpful
Hello - I have a Samsung xpress c480w & error message scan unit open or exit jam Tried all things -pls help..?. Thanks
To reset Samsung printer manually, firstly press the Power button until the LED light turns off. Before proceeding to next step, confirm that your Samsung printer is off. Now, you have to remove the power cable from the back of Samsung printer and then leave your printer unplugged for 10 minutes.
https://www.printerstechnicalsupport.com/how-to-reset-samsung-printer-firmware
How can I enter the Tech Mode to reset the counters?
Imaging drum reset chip Ebay £15
http://www.ebay.co.uk/sch/i.html?_odkw=Imaging+Drum+reset+chip+for+Samsung+Xpress+SL+C410W+Xpress+SL+C460FW+SL+C460W&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XImaging+Drum+reset+chip+for+Samsung+Xpress.TRS0&_nkw=Imaging+Drum+reset+chip+for+Samsung+Xpress&_sacat=0
Why are all lights on top are flashing, buttons not responsive and won't print?
The toner cartridge is empty,or you after refill the toner not change the toner chip.
Samsung how to
I NEED HELP WITH MY NEW TAB. I CAN'T GET IT TO PICK UP MY WEB SITE HELP
I want to reset Samsung ML 1640 printer.
Hi
Dear upgrade your printer firmware. this the one way to reset the printer.
For download the firmware Click hear and see the instructional how to upgrade the firmware.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
