I had to get a new mandrel housing which goes between one of the blades and a pulley on top of the deck. How do I remove the bearings and shaft from the old one?
You have to remove the nut on top of the pulley. With the pulley off, the shaft will slide out the bottom with the blade. Don't forget when you put the pulley back on, the washer/spacer goes BETWEEN the pully and housing, NOT on top of the pulley. Dwain
Put in vise and pound out shaft, if Berring seized I may have worn into shaft creating a lip keeping berring on shaft . Once you get it miving it might take other berring out with it if your lucky.carefully pond out other berring out with chizel, cleaning up (file, ect.) Any marring that mightve happened anti-seize ariund new berring befire seating for a next time.
