These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
SOURCE: Vizio P42HDTV Power on Diagnosis
Please check the U29 8 pin little surface mount mosfet it has this letters > FDS4935 > > In this part inputs 13.2 volts which is ok for the near 12 vdc but it > outputs 1.250 vdc i am 100% sure that this is all the problem > > check it out, and tell me if you´re agree with me > > On this output pin it feeds the audio Ic, the 7809 and the tuner side board > which needs de 12vdc too and its getting only the 5vdc part > > what do ya think?? > > Richard
SOURCE: TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
SOURCE: Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
SOURCE: LG TV won't turn on. Power light flashes red/green.
Power supply board just die.It can be dead at anytime.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Testimonial: "good advice"
