I apologize, but I need more information about the specific model of the Eclipse propane floor buffer to locate the manual and provide troubleshooting steps. Can you please provide the model number or any additional details about the buffer?
Use your volt meter to test the battery voltage. It should be at least 12.4v . I this is good, follow the voltage through the ignition switch and the relay if it has one, on to the starter. If you have power on to the starter, but still no crank, the starter is bad.
Hope this helps, Robert
The switch has gone bad. Very common on these. The contacts in the switch wear out and then get welded together. The motor draws a lot of power when first started and this is ******* the switch.
Other than design differences tension settings are much the same.
Check out these videos and you will probably find your answer. sewing machine tension YouTube
