SOURCE: Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
SOURCE: Kenmore 70 series washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
SOURCE: Why My Kenmore 70 Series Washer Won't Drain Or Spin?
You need to replace the lid switch. This is located under the case. you have to take the case off to change this part. This is done by taking the 2 screws out of the front of the control panel. Then flip the panel back and remove the 2 brass clips that hold on the case. Then you can remove the whole washer case to get acces to the lid switch. This is a very common problem and an easy problem to fix.
SOURCE: 70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
