Question about Kenmore 2800 White 27-in Washer Top Loading, 4.3 Cu Ft
I have Kenmore top loading High Efficiency low water washer model 2800 Everytime I was dark clothes such as black or blue pants they come out of the washer with white marks on them-- I do wash in cold water. The marks do NOt come off in the dryer. What can be causing that?
    Top Expert:
  • Kenmore Master
  • 55,370 Answers
You could be using powdered detergent which does not dissolve well in cold water.
Posted on Jan 16, 2018
Anonymous
SOURCE:
Anonymous
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Posted on Dec 20, 2008
Anonymous
  • 70 Answers
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Posted on Feb 24, 2009
seth adams
  • 1531 Answers
SOURCE: Rusting lid on top-loading Kenmore Washing Machine
that is very possible.the best thing to do is replace the lid or sand all the rust off and you some rust inhibitive paint to helpslow or stop the rusting proccess.
Posted on Jan 23, 2010
SOURCE: top load Kenmore 800 washer will not fill with water
OK - I have a solution to my problem with this washing machine. Nothing would work except for one of the spin cycles. I thought it was the main switch - the cycle selection and start switch - but I was wrong. The service tech replaced the switch behind the fabric softener. It's the switch that controls the water levels. Part # W10292584. Our government is forcing the manufacturers to put controls on the washing machine to save water. It's a bad idea and is causing lots of problems. Tech says he's replacing them on a regular basis. Less than $100 if you do it yourself. Hope this helps.
Posted on Feb 20, 2010
graemevm
Graeme van Malsen
  • 519 Answers
SOURCE: Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Posted on Apr 18, 2010
Tip
Top-Load vs Front-Load Washers - Things to Consider
The traditional top-loader is more comfortable to load and cheaper to buy. High efficiency washers in top-load or front-load models are much more expensive but are water and energy savers, with front-load models having the best energy ratings. Front-load washers have a better spin which leaves less water in the load causing less drying time. High-efficiency models require low-sudsing HE detergent due to low water levels and they require a little more care. They also have more cycles and convenience features than traditional top-loaders. Warranty periods generally are a year regardless of washer style.
on Aug 17, 2010 | Refrigerators
All my dark clothes have soap deposits on them and clothes seem exceptionally wrinkled when I take them out of the washer.
If load is wrinkled the load may have set in the washer to long it is recommended to remove wash as soon as it stops or the load was too large for the washer capacity. Loads must be balanced and move freely during washing. Also using too much detergent could cause the deposits on clothing. Using an he ( high Efficiency) detergent might help. Using delicate or another cycle with low spin speed will reduce wrinkling.hope this helps
Jul 01, 2015 | Maytag Bravos MTW6600T Top Load Washer
Does kenmore recommend liquid or powdered detergent for front load machine
liquid is best as powder is mostly made of a "clay base" in its detergents??? yes i did say clay!
Nov 28, 2010 | Kenmore Elite 45986 Front Load Washer
White streaks on dark clothes after washing.
Reduce the load !!
You are getting white streaks because the clothes are so compressed the machine is not agitating them correctly.
My daughter gets the same problem and she still insists on packing the clothes in.
My wife washes the same clothes for her with the right load and they come out fine
Jun 18, 2009 | AEG Lavamat 88840 Front Load Washer
Grey lint all over sheets and dark color clothes
less soap and shorter wash time or wash on perm press cycle but this is a common problem.
Jan 23, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 2800 White 27-in Washer Top Loading, 4.3 Cu Ft Logo
78 people viewed this question
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
James Hensley
James Hensley
