Question about Bosch SDS-plus BULLDOG Xtreme Rotary Hammer 11255VSR
How do I remove the drive end shield - Bosch SDS-plus BULLDOG Xtreme Rotary Hammer 11255VSR
How to install the alternator belt in a 2008 Suzuki xl-7?
which engine option, you do know belts are not same on all engines right? fact.
2.7L V6 or bigger? IDN.
same on all cars. (answering in generic form do to above)
loosen the tension-er.
take off old
put back new
and if not a spring tension-er,set proper tension
the fSM cover all this.
why not read the manual, RTM?
here is one example (get the book, RTM or see alldata.com)
2008 xl7 engine
Removal Procedure
Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement .
Install the engine support fixture. Refer to Engine Support Fixture .
Remove the engine mount strut bracket. Refer to Engine Mount Strut Bracket Replacement - Right Side .
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle .
Remove the engine splash shield. Refer to Engine Splash Shield Replacement - Right Side .
Remove the right side engine mount bracket. Refer to Engine Mount Bracket Replacement - Right Side .
Lower the vehicle
Rotate the drive belt tensioner clockwise to release the drive belt tension.
Slide the drive belt off of the belt idler pulley (1).
Slowly release the drive belt tensioner.
Remove the drive belt from the accessory drive pulleys.
end remove
beg, install
Install the drive belt to the crankshaft pulley, the tensioner and the generator.
Rotate the drive belt tensioner clockwise.
Install the drive belt to the idler pulley (1).
NOTE
Important: Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
Raise the vehicle.
Install the right side engine mount bracket. Refer to Engine Mount Bracket Replacement - Right Side .
Install the engine splash shield. Refer to Engine Splash Shield Replacement - Right Side .
Lower the vehicle.
Install the engine mount strut bracket. Refer to Engine Mount Strut Bracket Replacement - Right Side .
Remove the engine support fixture. Refer to Engine Support Fixture .
Install the the air cleaner assembly. Refer to Air Cleaner Assembly Replacement .
end.
Sep 07, 2014 | 2008 Suzuki XL7
Excercise bike clunking noise
please follow this steps and fix it. God bless you
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Nov 26, 2013 | Nordic Track Exercise & Fitness
I have a Proform Smart Strider. We just assembled it & when I tested it there's a very loud scraping sound when I stride, regardless of the level or program...help, pls. Thx.
I recomend you to disassemble again, and repeat the steps. Something must be there ARE not according with the instruction assembling. Try however for to see the some loose parts, bolts, nuts, and lube.
See this small instruction.s
God bless you
Lubrication:
Oct 15, 2013 | Proform Smart Strider SpaceSaver...
Belt falls off
see the next steps and fix it. God bless you
Drive Belt
Dec 18, 2012 | Schwinn 150 Upright Bike
The wheel on my elliptical is stuck. A couple steps and it got stuck. How do I fix that?
see this causes and fix it. God bless you
Lubrication
1 Drive Belt
Oct 14, 2012 | Exercise & Fitness
Older proform crosstrainer ( recumbent bike ) just assembled from box and when I pedal grating sound from pedal area?
B) Lubricate your FITNESS BIKE. very important.
Sincerely. Mery Christmas.
Ernesto Cuadra
Managua, Nicaragua.
Dec 24, 2011 | Exercise & Fitness
I have a Nordic Track Commercial 1300 eliptical that started slipping when we used it. We tightened the belt but it didn't help. What else could be wrong?
Step 1
Step 2
Step 3
sincerely. Merry Christmas.ernesto cuadra
Dec 18, 2011 | Nordic Track Exercise & Fitness
Belt came off and need to put back on
SINCERELY. GOOD LUCK.
ERNESTO CUADRA
MANAGUA,NICARAGUA
Nov 25, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
My Pro-Form 330 elliptical has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried switching the levels, but...
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 27, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
2000 eldorado etc. Radiator removal. All hoses and coolant lines disconnected. Have tilted the Radiator away from condenser and tried to lift Radiator out of clips with no success am I missing a step or do...
Factory service info. says nothing about the radiator needing to come out . Comes out from the bottom of the vehicle , alternator does .
Disconnect the negative battery cable from the battery. Refer to Battery Negative Cable Disconnection and Connection .
Remove the accessory drive belt. Refer to Drive Belt Replacement in Engine Mechanical-4.6L..
Remove the radiator support access panel. Refer to Radiator Support Sight Shield Replacement in Body Front End.
Remove the front engine splash shield. Refer to Engine Splash Shield Replacement in Body Front End.
Remove the upper front mounting bolt from the generator.
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Loosen the rear generator bracket from the engine.
Remove the top bolt.
Remove the front lower mounting bolt.
Remove the lower rear mounting bolt.
Remove the upper rear mounting bolt.
Remove the duct from the back of the generator.
Disconnect the following electrical connections from the generator:
• Regulator
• Battery output
• Heated windshield (if equipped).
Remove the front generator A/C bracket.
Rotate the generator and remove it from the vehicle.
Jan 25, 2018 | Cadillac Eldorado Cars & Trucks
Bosch SDS-plus BULLDOG Xtreme Rotary Hammer 11255VSR Logo
127 people viewed this question
Top Bosch Hammering Experts
John Trevino
Marvin
Marvin
Mike
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
