SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
SOURCE: need to know how to replace drive belt lawn tractor
Check out the video at the link that I am providing and see if it helps you with the drive belt replacement. Sure hope so and best wishes.
http://www.youtube.com/watch?v=YIRUAMSjGfg
SOURCE: need a wiring diagram for a craftsman lawn
http://c.searspartsdirect.com/lis_png/PLDM/P0502131-00001.png
This will take you to a wiring diagram
SOURCE: What year model is lawn tractor (mower), advice or solution
Hi there Avu
It's quite east to see when was your tractor was made, follow these simple steps and you'll know how to see what model it is
Hope this helps
Attached is an image of the tractor seat and the metal plate
Testimonial: "I did it and there it was, Thanks a lot for the help with the solution for this lawn trctor problem"
SOURCE: How do I chamnge the oil in my Craftsman lawn
There should be a pipe OR quick release valve coming out the right side at the bottom of the engine where it bolts to the frame. Most of the Craftsman riders I have worked on, had a long pipe with an elbow at the end of it and a plug in the bottom of the elbow for draining. Turn the wheels all the way to the left to allow enough room for a collection pan. It holds less than 2 quarts so the pan doesn't need to be too large
