Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Change defrost timer on roper rt14bkxkq03 top freexer
All videos show side by side refrigerator. I think I can change it if I see directions.
5 Suggested Answers
Techsim
James
  • 59 Answers
SOURCE: Roper whirlpool model 2314273-A
This sounds like a defrost drain problem. Behind the panel in the back of freezer is a heater that defrosts the evaporator and below that is a drain hole. They will occasionally get clogged or just freeze over Pour hot water down it until it thaws then check to see if the water drains normally. If it drains after thawing then get a small length regular electrical wire and twist one end around the heater. You should get enough to extend the other end 2 or 3in into the drain hole. Now when the heater turns on it will heat the wire and thaw any ice in the top of the drain.
If you can't get water to drain then there is something clogging the drain tube and you'll have to find a way to clear it. I use a steamer that has a small tip to build pressure and force the clog out. Hope this helps.
Posted on Nov 02, 2008
Anonymous
SOURCE: ROPER RS22AQXMQ SIDE BY SIDE REFRIGERATOR PROBLEM
I had the same problem with a top freezer. I found that the thermostat was bad by tapping on the it at the setting knob. The defrost timer was replaced first which did not help (repairman put in a timer for a Frigadair which will not work in a Roper). If one is used for a frigadair as soon as it cycles it will not work again until it is unplugged and allowed to reset. I replaced both the thermostat and the right defrost timer. It has worked great for over 2 months.
Hope this helps.
Posted on Dec 01, 2008
Anonymous
  • 105 Answers
SOURCE: Need to install defrost Timer
It is located in the center console which runs front to back in the food section on the ceiling. There should be just a couple of screws holding it in place
Posted on Apr 08, 2009
Anonymous
  • 121 Answers
SOURCE: I have a rooper top frezer refrigerator the
it seems to me that you have a clogged drain, that is located in the freezer compartment behind the panel. make sure that is not clogged. that will cause the issue you are having.
Posted on Oct 21, 2009
Anonymous
SOURCE: Freezer appears to work but the fridge has stopped
had same problem. fan quit working. just needs lubrication and a nudge.
joyce
Posted on Jul 18, 2010
Where is the temperature control panel of my GSS25JETA WW
It is likely there is no actual control panel, but rather a simple dial somewhere located towards the back of the inside the refrigerator compartment that has lettering that states, "warmer/cooler" with arrows that show which direction to turn to change the temperature setting.
Jul 04, 2014 | General Electric GSS25JET Side by Side...
The manual on the Maytag MSD2572VEW is extremely vague. It's time for me to change the filter but I don't know where it is or how to do it. Please help.
Your Maytag refrigerator is built by Whirlpool and uses a filter shown i video i have attached and that video will show you how to replace the filter
Gene
Aug 15, 2011 | Maytag MSD2572VE Side by Side Refrigerator
Warter filter
Check out this link, its a video that shows you how to replace the water filter.
http://www.youtube.com/watch?v=YRsvfaKABLI
Jun 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whats the working pressure of R134a in refrigerator
That question does not have a simple answer. The pressure is directly related to the temperature. You can go on line and get a table showing the pressure vs temperature. I would think 0 is a good starting point for the return temperature. High is also related to temperature. I would expect the high to be about 135 but that depend on ambient etc. You may have to have a licence to tap the refrigeration system and purchase gas depending on your locaton.
Good Luck,
Gilshultz
Dec 01, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer works, refrigerator doesn't, motor is making an odd noise
frost free refrigerators consists of -
1)Heater
2)Thermostat(bimetal)
3)timer
heater and bimetal are in freezer section. First check heater. Give it direct power supply. If it heats up,its OK. Then check bimetal. Immerse it in Ice. check continuity using a continuity tester. If its showing continuity its OK too.
change timer if both heater and bimetal are OK.
Aug 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Unit wont start display only shows (hrs) blinking.only fan in refrigerator area working this is a ge monagram side by side refrigerator. i tried to reset the control butten but display just goes on and...
ok i tapped out and called the repair man. he came and found out the main board is fried.
you have to change the board.
he charged me 350 total for everything.
so all you have to do is order the board and do it yourself.
board is around 200-250 i think
Mar 11, 2009 | GE Monogram ZFSB26DRSS Stainless...
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
63 people viewed this question
Top Roper Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Gil Shultz
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
