. The "dating" service is intended more for dating and documenting the older collectable guns that are no longer in production and were made prior to 1980.
"F" prefix with a serial number lower than F498821 = 1989 thru Nov. 1st, 1995
"F" prefix with a serial number higher than F498821 = Nov. 1st, 1995 through the end of 2002
"G" prefix started in 2003 with the introduction of the AccuTrigger
"H" prefix started in January of 2010
Go to the proper symbology page scan the prefix start then find the tab character and scan it three times to add the prefix then scan the complete barcode for the prefix
"BELL" has no prefix because you didn't write one.
Some words can have several prefixes or suffixes. There is no answer to your question since you wrote a word without a prefix. It would be the same as asking what is the prefix of "manufacture" as this word has no prefix; however, if you asked what the prefix of the word "remanufacture" is, one could answer that the prefix is "re". If you asked what the prefix and suffix are of the word "re-manufacturable" I would answer with Prefix = re, Suffix = able.
What word has the prefix plac-? Surely you don't mean "place," which has no prefix. If you mean "placoderm," it means "plated" or "plate-like", and "-derm," means "skin." If you mean "placenta," I'm not sure it has a prefix, either. Plac- is probably more of a word root than a prefix.
Inserting a dial prefix
A dial prefix is a number or group of numbers that are automatically added to the beginning of every fax number you enter at the control panel or from the software. The maximum number of characters for a dial prefix is 50.
The default setting is Off . You might want to turn this setting on and enter a prefix if, for example, you have to dial a number such as 9 to get a telephone line outside of your company telephone system. While this setting is activated, you can dial a fax number without the dial prefix by using manual dial. For instructions, see Using manual dial .
To set the dial prefix
On the all-in-one control panel, press Menu .
Use the < or the > button to select Fax setup , and then press .
Press the > button once to select Fax Send setup , and then press .
Use the < or the > button to select Dial Prefix , and then press .
Use the < or the > button to select On or Off , and then press .
If you selected On , use the alphanumeric buttons to enter the prefix, and then press . You can use numbers, pauses, and dialing symbols.
Prefix/Suffix Dialogs The Prefix/Suffix Dialogs allows configuration of DataWedge options. Two data entry fields are used to display and allow entry or editing of prefix and suffix strings. The prefix string, if present, is transmitted before the data for any barcode scanned. The suffix string, if present, is transmitted after the data for any barcode scanned. The following checkboxes are used to display and allow modification of various DataWedge options: Allow escapes in prefix/suffix (default = disabled) Enabling this option allows escape sequences to be embedded in prefix and suffix strings. Escape sequences allow non-textual data to be transmitted as part of the prefix or suffix string. All escape sequences begin with the backslash “\” character. The supported escape sequences are: \b Backspace \f Form feed \n New line (line feed) \r Carriage return
