Hello and thank you for choosing fixya. Many times when your hydrostatic transmission will not engage, it could be due to a loose, worn, or broken belt.
Check to see if your belt is still around all of your pulleys. Also, check to make sure that your belt is tight. Your mower has a bypass rod. This is the rod that you pull out, in order to release your bypass lever on your transmission, when you need to manually roll your mower. Lets make sure that this rod is fully releasing.
Double check your axles. If you have recently removed one of your rear wheels, and did not slide the square key, back into the keyway on your axle, this prevent your mower from moving when you engage your transmission.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/donald_932dff968258421f
SOURCE: hydrostatic transmission will not engage
Check the drive belt and make sure the relief valve is in the drive position if this looks good you need a new trans or get it repaired.
Sam
