I have a Uline 1175RS beverage fridge with a loose door handle. There is no obvious way to access the bolts which are on the interior of the door. How do I gain access to the bolts to tighten the handle?
There is indeed a simple solution if you are at all handy with a drill.
1) simply remove the rubber "weatherstrip" from the inside of the door.
2) pick your largest drill bit and from the inside drill through the black plastic EXACTLY opposite the door handle bracket. Make sure you line up north south and east west.
3) what you will uncover is a small Phillips head screw. Tighten and your handle will be tight.
4) replace black rubber "weatherstripping" and you are done. EASY!
Hi
You are right. The only way to repair this is by replacing the complete door assembly. If under a year it should be covered.
I know this is old but our 1175rs has a stainless handle and it has set screws in it to hold it on the door (hard to see but they are there)
