SOURCE: FORGOT HOW TO RESET INK LEVEL INDICATORS AFTER NEW REFILL
http://www.abacus24-7.com/installdell.htm Here is a is a link to a page with detailed instructions on how to reset the ink levels for your printer.hope this helps you out . biigg53566
SOURCE: reset ink levels on dell 944
If you refilled the cartridges, you may want to try new Dell branded cartridges.
SOURCE: Reset the ink memory level after replacing cartridge
Have you tried to unplug your printer and plug it back in?
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
I am one of the Dell Certified System Expert that work with Dell Printers before.
For this case first is try to check level of Ink.
-Click start or Windows logo.
-Go to All Programs or Programs, then select the printer program folder from the list.
-Select Printer or printer home.
-Choose your printer from the printer drop-down list.
-From the Maintenance tab, Check ink levels.
If the ink level is very low to none replace the ink
If the printer level is ok, try to run the test page to check if it will print colored, if it is the issue is only in the settings of the printer.
here is how to run test print
-From the Maintenance tab, click Clean Cartridges.
For more information about your printer here is the link:
http://support.dell.com/support/edocs/SYSTEMS/PRN_V715w/en/ug/en_ug.pdf
I hope this will help you a lot in resolving your issue.
Thank you for choosing Fixya
