Our maytag neptune electric dryer works, blows heat out back duct, but takes up to 90 minutes or more, to dry clothes and even then, not completely dry, our washer spins clothes dry, so i ruled this out, but inside the dryer it always seems real moist or wet.
does anybody have any answers for me, and if so i would appreciate your diagnosis.
thanks. scott
I suspect you have a blocked air vent. A blocked vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
thanks for the answer, that worked and now it made since to what it was doing.
thanks for the reply. scott
