I need the code for a Sansui tv
SOURCE: rca digital converter box tv codes
You need to go to the manufacturer's website for the instructions.
In addition:
I wish someone would bring a suit against any of these manufacturers using the term 'universal.'
At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
There may never be a code for your brand available in every remote.
SOURCE: codes for magnavox tv for rca converter box
005 007 045 049 050 054 055 064 097 098 099 153 154 160 170 174 177 181 210 230 234 252 258 259 272 274 283
Hope one of these works for you.
SOURCE: I need codes for a mitsubishi tv on a RCA dtv800b1 digital box
here you go.....
Mitsubishi 0 0 9 3 ,0 1 5 0 ,0 1 7 8 ,0 0 1 9
Please rate our help++++Thanks for using FIXYA
SOURCE: Programming RCA converter box remote control with Phil/Mag TV---
Good day,
You should have the instruction guide. If not look below. It's there but look closely for the guide itself and how to increase it's size to readable.
Check on the back of the TV to see if there is a 3 and 4 setting, If so, set to 3.
With nothing connected to the tv, and using the tv's remote, scan for channels. It should come up with only channel 3.
Then using the remote with advanced options, set the the input to either antenna or auto.
Connect the antenna cable to input on the converter box. Using the supplied cable connect the output from the converter box to
the TV. Turn the TV on first, followed by the converter box.
Then follow the instructions.
Not really easy so you'll have to fight your way thru it.
Finding the right setting for the antenna will probably take the most time, requiring a station scan after each adjustment.
http://dtvconverterboxes.blogspot.com/2009/05/rca-dta800b1-owners-manual.html
