Tractor was having some difficulty starting so a bought a new battery put it in and it started up fine. It was running for about two minutes in the garage and it just stopped. When I tried to start it again there was nothing. No lights or power of any sort. I even tried to jump start it and still nothing. It is not getting any current. Fuse? Silk kid?
SOURCE: 2140 cub wont turn over when trying to start
Change the solenoid, if you can jump the posts on the solenoid and the engine turns over...the solenoid is bad
SOURCE: I have a cub cadet 1550, Blew fuse and wont disengage from gear
You have a bad wire which rubbed on the plastic housing to the engine block near the starter mower which causes a short and blows the fuse. I have the same tractor and this happened to mine also. The wire is red.
SOURCE: cub cadet 2135 wont start
check for a fuse behind the ignition
it might be blown
then i would check the starter solenoid
if you put a screwdriver accross the bolts that hold the wire from the starter and ignition switch and it tries to start there's ur problem.
Testimonial: "So after borrowing the neighbor's tractor for a month, I finally checked the fuse and YOU WERE ABSOLUTELY RIGHT!!!! Blown fuse! You're BRILLIANT! Tnx!"
SOURCE: cub cadet has no power changed battery still no
Blown fuse. There is a fuse somewhere thats blown. It will be about a 15 amp in a fuse holder either back by the battery or behind the dash. U didnt specifiy the 100 number If thats a starter-gen it could be a reg- relay issue.
