I had the exact same problem. It was the evaporator coil had a leak. The coil is covered under waranty the labor is not! It was $295.00 labor and $48.00 for the gas recharge.total $343.00. Hope this helps! Yes, the price was high but it fixed the problem.
Part # was 4204420
Ed
SOURCE: Model GE TBX16SPCL Water dripping from
Michael, I live in an apartment that has this model. I had a similar problem that the apartment maintenance man concluded was a clogged vent. I don't no precisely what he did to fix it but it involved opening the vent compartment and cleaning it out. Be sure to take everything off the shelves of the refrigerator before your start because it makes a mess. Good luck.
SOURCE: Water dripping inside top of refrigerator.
if freezer is on top what is happening is your drain hole behind freezer panel is clogged
SOURCE: looks like water dripping from frezzer, but there
you have a blocked drain.i use a steamer to clear the drain,they cost around 50 bucks,take off the back wall.melt out ice with hair dryer,crack out as much ice that you can with plyers or hammer,gently hit it and it will crack out if the floor is a sheet of ice and a putty knife comes in handy,when you melt out and remove ice stick the tip of steamer in drain and clean the drain out,hit it for 10 seconds then stop wait a minute and hit it again,you don't want to damage the drain line it's plastic so take your time,pour hot water down drain to make sure it's clear you might have to use hair dryer and heat up the inside of ceiling in the fridge section in the middle of back wall and ceiling where the drain is, the air ducts are there also,whenwater stops dripping you'll know you melted all the ice,good luck
SOURCE: drips of water appearing from vent area at top of
Check your defrost drain for blockage and look under the freezer floor for an ice dam.
Eric
