TRied holding in on button like the instructions say only gold lite will come on. White to operate will not.
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: 46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
IT SHOULD BE UNDER WARRANTY. TAKE IT TO AN AUTHORIZED VIZIO SERVICER.
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
