The door unlocks in the spin cycle and an Error E:20 shows in the display.
SOURCE: My washer wont spin it shows an error e 13.
If your washer won't spin, check these:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Thank you for contacting Fixya.com
SOURCE: Bosch Washer WFMC3200.
Contact a Bosch technician. You may have to at least pay for a service call.
SOURCE: my 1995 bosch classixx washer will not spin even
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Plug off the wall first.
Remove rear panel of washer, and undo 2 screws that secure the motor,
lever motor back with a screwdriver or similar, and unplug motor lead. Be sure to keep hold of the motor so it does
not drop on the floor.
You will see the brushes at the terminal end of motor, if they are any shorter
than 1 cm replace brushes.
Sites for spares: (quote brand & model)
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
mcminone.com
Normal
0
false
false
false
font-size:10.0pt;
Pl give me a ‘very helpful’ rating for the free help,
thanks!
SOURCE: The E:02 display was flasing with the spin light
try unpluging it for a few min. then plug it back in.
SOURCE: We have a Bosch Nexxt 100 Series Washer. The door
Getting the door open is the easy part. Finding out why it won't open might take a little doing -- though replacing the door latch is also easy. To get the door open, Take an awl or something pointy and place it in the hole on the small round cover in the lower left front of the machine. Now use this to turn the cover, unscrewing it from the machine. Once the cover is off, you should see a plastic rod hanging down. Pull this rod and it will unlock the door. You can now remove your wet clothes from the machine and investigate the cause of the problem.
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
