SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
SOURCE: Bosch Vision 300/500/dlx Series Clothes
Im getting an error e13 message and don't know what to do
A code E27 means a problem with the door lock. Try
unpluging the machine for an hour and see if it resets the lock. If not remove the cover on the lower right
corner you will see a white plastic pull cord. Pull the cord and pull open the
door. If that doesn't reset the door lock you will need to replace the lock.
This code means an error code. That the dishwasher electronic control has detected a condition it needs to check. When you see a code, follow these steps to solve the problem:
· Press "Stop/Clear" to clear the display and stop the beeping if any.
· Reprogram the dishwasher.
· If the code still displays, turn off the power to the dishwasher at your breaker box and wait five minutes and clean all part (area) that are open to water carefully before turning it back on.
Thanks for using fixya
