Brand new but dies not make much ice
SOURCE: Water not getting to ice tray
Sherman usually (not always) the problem is a frozen delivery spout coming in back of the freezer. look where your ice maker and on the back wall and up behind that you will see the delivery spout area. The water valve may be bad or not opening also but it most likely has 2 solenoids 1 for water in the door and 1 for the ice maker. If you have checked and have the ability turn off the water and reverse the water inlet lines on the water valve. This is just to make sure the water passage is open. Hit the cold water cupplunger then look and see if you have water that cam into the ice maker if not your problem is in the valve or the line to the ice maker. Next hit the same plunger with the water line disconnected if you have water then your problem is in the freezer delivery and needs defrosting and cleaning if its a plastic spout it probably has lime covering it inside and freezes over or the water valve is leaking by a little and refreezing. with the water line off yuo will quickly know if its leaking by. and cover with a towel to prevent a mess if it sprays out when you try the plunger. If it still dosnt work try to check the coil on the water valve both coils should read about the same. If after all this works and you have water everyplace (thats why I said use the towel) the problem is in the ice maker circut. Either it is the main power, the ice maker motor its self, or or most likely its the fill valve switch.In any case if you purchase a new replacement Ice amker head all this will be new.OR Either replace the switch if it checks open or if its loose or there are broken parts. It requires a cam to open and close the switch so it only opens for about 5 to 15 seconds. .Hope this helps you let me know if I need to tell you more. Rate me accordingly please and Good luck.
SOURCE: Amana Side by Side - will not make ice - has new filter
did u try to check the solenoid valve in the water intake to the ice maker?.. it might be damage, check the frezzer temp.. might a little bit high, and check is there water in the ice maker, or theres is no obstruction in water hoses behind the refrigerator.. i hope this helps! :)
SOURCE: bad frost keeping building up around ice dispenser
This is usually caused because the door is not shutting all the way or not tight allowing air in.
There is a solenoid that operates the door that
could have stopped working. Can you hear it?
The hinge on the door could be broken or the
bracket it goes in could be broken. You'll have to look to see what's
wrong.
Remove the dispenser cover by gently prying starting at the
bottom going round and round a little at a time to prevent from breaking it.
When it's off the screws will be exposed to access the other components
Testimonial: "Very helpful info, until now I did not know I could take out the ice bucket, there was a lot of built up ice behind the bucket.Thanks very much. "
