Hi, The picture quality is too dark on night scenes. You can hardly see the picture. Do you have any suggestions or a fix for this problem. The bulb seems to be good. Carron
SOURCE: dark screen
your tubes are getting week, they can be adjusted up but will only make them weaker.
SOURCE: picture fuzzy on dark scenes
Well I finally had the TV picked up by a Toshiba recommended repair place and they are saying that it is a bad Optical Block, also known as the Light Engine. Total for pick up, parts and repairs is $827.00. This seems ridiculous to me when brand new TVs are so much cheaper now. I don't think I will pay that much to have this one fixed.
SOURCE: Ultravision image dark
Good Day, tfarmer;
Since you have replaced the lamp, which is the normal cause for a dark picture. Have you checked your video settings?
The brightness level should be set at about 55 to 60%, the contrast should be set at about 90% and the video temp should be at normal or high.
If all these are set about this way, then I would think that the light engine might be going bad.
Good Luck, big IRISH.
SOURCE: Mitsubishi WD-62527. Dark picture.
That unit is a two mirror set. Meaning the light engine lens shines down onto a small mirror and that is reflected onto a large mirror and then onto the screen. Gravity being what it is dust and other contaminants cover the lower mirror. Moving the set would only aggrevate dust settling on it. To fix the problem the screen must be removed and the mirror cleaned. You won't believe the difference. It will be like watching a new tv.
SOURCE: Picture seems to be quite dark when watching
Turn ALS off. IT is in the same menu as brightness.
