Hi -- I have a Whirlpool Duet frontloading washer, model # GHW9150PW0. I got an f02 error, so looked up youtube and figured out how to remove the bottom panel and cleaned out the drain. I unplugged the machine before I did this. The washer was full when I opened the drain, lots of water came out. Anyway, there was lots of debris in the catch drain, which I removed. My problem now: when I plug the washer back in, the washer won't start. No lights come on. The outlet definitely works because it was working just before I unplugged the machine (it was mid-cycle) and when I plug in now, lights on the dryer, which has the same power source, come on. I would appreciate any help!!
SOURCE: Duet washer door locked
Pull the front panel off, look for a plastic piece , it has a filter that you need to pull out. turn it to the left pull it out and clean it. This solved the problem for me. had the same issues.
SOURCE: whirlpool duet ht wouldn't start
remove the lower front panel,3 screws,side up and off,there is a tech sheet inside on the panel that should help you ,let me know what you find-mike
SOURCE: No power to Whirlpool duet front loading washer
sorry no reset on that model but check the outlet
