Question about Amana Refrigerators
Amana srd522 compressor is working but fan is not going
Anonymous
SOURCE:
MARK FISHER
  • 87 Answers
SOURCE: fan for amana fridge
Not sure of the description of the fault. If you are saying that the internal fan will not run but that you have put a power supply to it and it has run, it could be a number of possibilities... You described moving the cabinet. It is highly possible that a pipe or part of the refrigeration system has been damaged in the move and caused a loss of gas. If you remove the back panel to expose the evaporator (cold coil), and turn the system on, after 5 to 10 mins you should see a frost build up over the whole of the coil. If you dont then you probably have a leak. Result call a fridge guy. Leaks can vary in cost and is entirely dependent on where the leak is located and how long it takes to find it. If it does freeze the whole coil then you may well have a problem with the defrost heater or defrost thermostat. Both of which need to be intact in order to provide a neutral supply to the fan motor. You can (IF COMPETENT) check that you have resistance across both of these elements. If you have an open circuit on either then that is your problem. (PLEASE REMEMBER THAT THE DEFROST THERMOSTAT HAS TO BE BELOW 0'C IN ORDER TO HAVE ZERO RESISTANCE ACROSS IT...I.E. COIL COLD). Hope this is of some help.
Posted on Sep 08, 2007
Carmen Mikulic
  • 415 Answers
SOURCE: Amana SRD522
sounds like water line is blocked with frozen ice. have a technician clean the line and check the icemaker and water line for any kinks.
Posted on Sep 13, 2008
Healeyman
mike kirschbaum
  • 1198 Answers
SOURCE: Compressor and Compressor Fan Not Working
Rotate the dial on the defrost thermostat, a big click is when it goes into defrost, a little more and it should turn the compressor back on. By overload protector, do you mean the one under the compressor cover?
Posted on May 03, 2009
Anonymous
  • 40 Answers
SOURCE: Amana ARB9059cs: compressor makes loud noise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Posted on Jan 25, 2010
walterkunesk
Wally Bald Guy
  • 683 Answers
SOURCE: Amana ABB222DE is the overload/capacitor the same
I have been doing refrigeration for over 30 years and I have never seen a compressor with a chip inside of it. Have you tried cleaning the condensor coils? I almost sounds like you have a weak start capacitor. Let me know if i can help you any futher.
Posted on Apr 24, 2011
Testimonial: "quick response thanks very much!"
Refrigerator & frezzer no longer cooling. Compressor is still running , but condenser fan doesn't seem to be working correctly. Does the fan not working full time when the compressor is running...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 23, 2011 | Refrigerators
We turned on our 1.5 hp air con Fujita on the heat setting, the compressor would run but the fan would not work. The compressor became noisier so we turned it off. On the cool cycle the compressor ran and...
the compressor got noisier be cause the head preasure was going up putting a strain on the compressor check all your wires from the fan motor and make shure they are all hooked up and than check the capacitor for the fan it may be bad usualy it will leak fluid or be swollen when bad. but not allways if you can turn the fan by hand is prob. not bad its prob. another prob causing it not to turn
Sep 30, 2010 | Heating & Cooling
Refrigerator does not cool. Freezer does not Freeze. Motor works. Fan Works. Timer works.
Are you sure the compressor is running. Are you going by sound, feel, amp draw. The fans can make you think that the compressor is running in reality it is not. Only way to tell is remove the back at the bottom and touch the compressor to see if the vibration is felt. If not the compressor is not running and you will need new overload relays which is a fairly inexpensive repair.
Mar 03, 2010 | Kenmore Refrigerators
Fridge acts like compressor is not coming on - Maytag wide by side - seven yrs. old
Pull the refrig out and remove the back panel . You should see the compressor and the cooling fan ( condenser fan ) . If the fan isn't working , it needs to be replaced . If the compressor isn't running or starts then cuts off , then the box plugged onto the side of the compressor , with 3 wires going to it ( overload/relay ) needs to be replaced .
Oct 31, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Freezer is defrosting and refrigirator is not cooling
If the compressor and the fan work , probably the unit is laeking freon, but if the condenser fan doesn't work ,the compressor will go of on overload, also the problem could be with the compressor relay.
Sep 19, 2009 | Kenmore Refrigerators
Fridge/freezer warm, water puddling underneath
Hi, clicking sound from compressor, means compressor not running (working) compressor overlay relay is what making that clicking sound, possible your compressor have a hard start, you can purchase compressor ( hard start kit ) from appliance store, your fans could be working, but compressor short cycling, you said fan not working? which one inside of ref, or one near to compressor, check fan, remove 2 wires from fan terminal, use ohm tester, place tester lead one on each fan terminal, if you get a beep sound (continuity) fan is o/k, if not, fan burnt out, replace fan, now if compressor is good, fans are good, then check or replace, defrost timer, but before doing any repairs, unplug ref, excessive water is because ref defrosting, because there's no refrigeration, remove your produce, leave ref. off for about an hour, then replug it, let it work for about another hour, then check to see if temp. dropping (colder) maybe you experiencing, low voltage, let me know what happened, then i can tell you exactly, what's the problem. good luck.
Aug 11, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Jun 11, 2009 | Goodman CKL60AR60 Air Conditioner
A/c unit not working
So only fan is running, the compressor not running okay check the voltage going to the compressor. The connection is coming from Thermostat or temperature controller, if there is supply going to A/c Comp. check the safety thermostat relay above the compressor.
Jun 01, 2009 | Heating & Cooling
May 03, 2009 | Refrigerators
99 Grand Am Cooling Fans Won't Work
there is a sensor on the motor behind the throttle at least thats were it is on my 99 grand am se and you can short that plug out and the fans should come on they should come on the with the ignition and go off with it
Jan 08, 2009 | 1999 Pontiac Grand Am GT
Refrigerators Logo
54 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
