I think is is this model purchased in 1991 with the pull down door on the front.
HAS SHOCK ABSORBERS WHEN THEY GO BAD ONE SIDE CAN LEAN ALSO CHECK FOR BAD OR LOOSE BALANCE WEIGHT. LOCATED NEAR THE MOTOR.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
