The travel trailer is plugged in to 120 volt system. With cold snap coming, I set the thermostat at 48 degrees to keep the camper inside warm. After the cold front came in I went to check on the condition of the camper. Found that the heating system would only blow cold air no matter where I set the thermostat. Switched over to propane to keep the camper warm inside. Any help would be appreciated. Thanks Gary Landry
Contact your local retailer/service center directly or online here
Plug in a ceramic 120 volt or oil type space heater to keep trailer warm. Most travel trailers are propane only, they do not have electric heat strips. I would bet that is why it only blows cold air.
Testimonial: "Thanks for the feedback Jim, but the thermostat does have a electric heat setting and a gas heat setting on it. Your comment leads me to think the heat strip may not be working. I don't know much about the wiring of travel trailers and if the heat strip would be on a separate circuit from the blowers and not getting electricity or just broken. Gives me something to look at. Thanks again. Gary"
